1 - 4 of 4 Posts
Ok guys, need some help.
2005 WRX ABS on constant at ignition. No flashing on or off.. just stays on.
OHM tested all sensors ..OK
Swapped ABS pump.. OK
Vehicle had a a turbo gauge as well as a turbo timer installed from previous owner. No idea if this is a direct cause or not.
Any and all help would be appreciated!!!
have you had somone pull the code? ohm testing a sensor doesn't really tell you if its good or not, there is a spec for most vehicles on checking the switching voltage w/ a certain wheel rotation, also inspect the abs rings themselves for damage or improper gap, although I own a wrx i have never had to work on the abs system, i am very familiar on how they all work, wrx use a 2 or 3 wire sensor? if its a 2 your looking for a/c 3 wire dc voltage.
I am not sure what the spec is on a wrx but for instance a typical abs sensor (2 wire) has typically 1 volt of ac when the wheel is spinning typically 1 revolution per second, you would want to check this voltage w/ the sensor connected by back probing any connector between the sensor and the module, I don't have a subby WSM handy, but I know for instance ford WSM's have this spec available in the ABS section. Also a chipped or missing tooth, or improper gap can cause this light. Unfortunately a 2 wire sensor means its a VRS sensor (variable reluctance sensor) and is very susceptible to improper gap and tooth imperfections, a 3 wire (hall effect) is much harder to effect... but obviously subby didn't use it.
1 - 4 of 4 Posts
