1 - 4 of 4 Posts
Ok so, i just recently discovered that they are a different pattern, so i looked up the available sizes on the OZ Superleggera's and they do come in a 7x17 5x114.3. But the offset is 45mm instead of the 48 that comes with the 5x100.
Will this be an issue if i run 225/45/17 Tires for rubbing etc?
Moderating on the run!
225 w/ 45mm ofset will not be a problem, particualrily w/ a sedan. I'm running 225/50/16's on a wagon w/ 46mm offset (Volk TE's).
I'd go wider in the rim personally, if they offer it- 7.5" (8" even better).
Big Sky
Ok, well i did find a place that i can buy the Superleggera in 17x8 with a 48mm offset on 5x114.3 which is what i would need for the 05.
Think that would work out ok?
That would work perfectly:)
1 - 4 of 4 Posts
