1 - 4 of 4 Posts
I have a 2022 Subaru WRX and I have a set of 05-07 STI BBS rims and tires. I have provided the bolt pattern to the 2022 Subaru WRX and the 05-07 WRX STI BBS below. I know that the bolt pattern will work seeing that I have a 5x114.3. I'm not to sure about the rim size? Would anyone be able to confirm if this will work or not on my car?
2022 Subaru WRX - Bolt Pattern
PCD: 5x114.3 (5 x 4.5)
Center Bore: 56.1 mm
Thread Size: M12x1.25
2005-2007 WRX STI BBS - Bolt Pattern
Offset: +53
Bolt Pattern: 5x114.3
2010 Subaru WRX Limited Hatchback 5MT
You need to know offset. Or take a wheel off and test fit. See if the brakes and suspension clear.
Either way, I don't think they'll suit the car.
In Æternum
It's unlikely that Subaru changed the hubs on the VB chassis compared to the VA Chassis, so I'll go out on a limb and say they should work great. To be more analytical about it, I would also echo what @a5m said above... you should determine the offset of the OEM wheels to be certain.
I run them as my winter wheels on my VA STI.
Wheel Tire Vehicle Car Snow
  • Like
  • Wow
Reactions: Drama.308 and a5m
1 - 4 of 4 Posts
