1 - 14 of 14 Posts
If anyone know if there's going to be problem using the 04 sti radio to my 02 wrx wgn...Qestion is, will it fit? Well, i'm cheap :redface: so why the hell not plus radio is about to give......Thank you
Sorry Bro, but the '04 STI did not come with a radio.
Your right 'bout dat, Thanks.. I checked out the stereo last night and realized 04 does not come w/ stereo :screwy: .....it was a Jensen so, took it anyway, better than the stock one's........and at no cost!!!! Thanks again for your response/ reply have a good day.......
For free you wouldn't take it, come on now! Anyway stereo isn't that bad lookin' actually I like it...mine's 'bout to give up the ghost anyway! Thanks for da honest opinion though..
Discussion Starter #7
hey, could get him at TArget! :rotfl: this is Temporarily/ for the time being, till have money for the real stereo upgrade....unless, you know wat's wrong with my radio for instance left passenger front speakers goes off till i turn up the volume and would work....replaced the speakers still not workin' properly, all connections are correct to my knowledge......
ClubWRX.net Vendor
Try a new stereo.
Anyway, why do you want to know about the 04 STi radio??? You need to wire up the entire car and install speakers. If you just install the radio, well....it'll work and all, but there will be no sound. So .. unless your deaf, this could potentially be quite frustrating.
ej20fan said:
Try a new stereo.
not really sure what you are talking about here, the 04 sti is all wired, all you need is a head unit and speakers. the antenna is in the back window and wired to the dash.
ClubWRX.net Vendor
04, usually does not have any speaker wires, pull off the door panel on a completely stock one and you'll be amazed to see the lack of any cable. Here in Cali, I've yet to see a stock 04 STi with wires that were not added afterwards. So if yours is completely stock, the way it was when it rolled off the boat, then it should have no wires in the door. Hence the lack of sound when you hook up the radio.
the wires are there man, you just have to look for them. mine was used, 3000 miles, but the previous owner had no stereo at all. the wires were there in all 4 doors taped up and clipped to the door.
these are the factory wires, i was an installer for 4.5 years and i know factory wiring from aftermarket.
also the 04 sti has a harness in the dash just waiting for an aftermarket radio.
do some searching, you do not know what you are takling about (sorry no offense inteded)
Discussion Starter #13
Hey, take some EX-LAX guys......no need for commotion here, I admit i made an 3rr thinkin the 04 had a stereo coz he upgraded his radio so, my thought was the my05 stereo..... :sadwave:
oh i am not worked up, if you get worked up over an internet forum you have issues.
i was just having a conversation about the car i own. :)
all is good on my end.
1 - 14 of 14 Posts
