Hi all,
I have an 03 WRX that is bone stock and had a code p0420 for bank 1 cat. I changed out the downpipe/stock cat with a Bosal "oem" cat. Looks to be pretty much the same minus all the heat shielding the factory cat has. I also put on new multi layered steel gaskets to ensure the whole system would be leak free. After putting the cat in and clearing the code with a cheap scanner the car felt 10 times smoother on acceleration and made better boost (factory cat was a little clogged). After about 35 miles of driving the CEL came back and it still reads the same p0420 for bank 1. Should I be resetting the ecu in a different way? Have I purchased a bad cat? (It has 5 year warranty) am I troubleshooting incorrectly? Could it have something to do with the turbo? It does have 140000 miles. Any and all advice on what to do next is greatly appreciated. Thank you for your time.
