1 - 9 of 9 Posts
Super Moderator
R180, if I'm not mistaken you have the r160 now.
Odd modification choice though with the rwd.
Yes there’s the R180 if you wish. However unless you’ve broken the R160 there isn’t much point.
Super Moderator
Xj man why is it an odd mod? An SD why isn’t there much of a point?
Because nothing about the car is designed to perform as rwd. The welded center diff is just a massive failure point. Not only because of the weakening of the diff from the weld, but because the diff is designed to have stress on two sides not one.
It is just really cumbersome and awkward to do. I've read quite a bit on it. The cars handle poorly and are near unusable in inclamate weather. So they are not good on a track or daily driver. I just don't get it.
If you like it though run with it
Discussion Starter · #6 ·
I don’t drive it everyday, an it’s fun to drive rwd 20psi an it just rips the tires right off, I did cause it was something new for me an it’s just fun I can make it awd in 2 hours still Even have my front shafts in still
Super Moderator
The r180 is all i know of, but how much stronger I don't know. None of them are strong in my opinion
1 - 9 of 9 Posts
