02 wrx rear/trunk wiring harness 81502fe270- $60
02 wrx battery cables come with free undertray- $15
02 wrx rear wiring harness 81502fe030- $50 (fuel tank connector missing)
02 wrx fuel hanger assembly with sti fuel pump- $50
02 wrx dash fuse block with all fuses/ relays- $15
02 wrx cluster wiring harness 81302fe000- $20
02 wrx engine bay fuse block with all fuses/relays- $15
02 wrx factory clarion radio antenna ef-1152a-c - $15
02 wrx fuel pump control unit Denso 22648aa011- $15
02 wrx keyless entry unit module 88035fe021- $15
02 wrx integrated unit 88281 fe021 575202- $10
02 wrx daytime running light module 84067fe000- $5
02 wrx fuel injector resistor module 684227- $10
02 wrx ignition relays bracket assembly- $10
02 wrx daytime running light relays bracket assembly (blue+black)- $10
02 wrx HVAC blower motor relay Denso 056700-5260- $5
02 wrx G sensor assembly, abs 27540fa022- $15
02 wrx flasher relay 020301- $5
02 wrx fuel damper valve- $20
02 wrx trunk light rear cargo- $5
02 wrx 2 door ajar sensors- $6
02 wrx cruise control button switch- $10
02 wrx LH side impact crash sensor- $5
02 wrx RH side impact crash sensor- $5
02 wrx LH front sub crash sensor- $5
02 wrx RH front sub crash sensor- $5
02 wrx LH front outer airbag seat belt- $30
02 wrx RH front outer airbag seat belt- $30
02 wrx airbag module- $15
02 wrx passenger dash airbag assembly-$40
02 wrx hvac core case- $50
02 wrx hvac control unit assembly- $15
02 wrx hvac blower motor assembly- $30 or take offer (Housing assembly got hole and I patched it on both side and side)
02 wrx clockspring- Trade for 04 sti clockspring?
02 wrx abs module- Trade for 04 sti abs module?
05 wrx ACT pressure plate- Trade?
05 sti oil pressure sender with bolt plug- $10
04 sti yaw sensor sensing-direction 499100-0430- $15
04 sti later g sensor 27540fe001- $15
05 sti turbo stock inlet- Trade for silicone turbo inlet? (Prefer red)
05 sti VF39 turbo (slight shaft play)- Trade for little big turbo? might pay little more (Let's negotiate)
05 sti steering wheel with airbag- Trade for 04 sti steering wheel with airbag or 04 sti airbag?
05 sti side feed fuel injectors and PE850 cc side feed fuel injectors (less than 100 miles used and cleaned service by fuelinjectorspecialists.com in Denver)- Trade for 1000cc side feed fuel injectors?
05 sti stock header & up pipe- Trade for aftermarket header & up pipe? (Let's talk)
Crawford fmic aos v2 with wrinkle red painted- $250 (Have all fmic hoses, it's not in this picture). It can fits on tmic and you will only need to buy tmic hoses.
I'll throw in free 02 wrx 2 Panasonic relays ca1-dc12v-n aca 3213 and free 02 wrx inlet fuel filler bracket without fuel filter if you purchase any of my parts.
I prefer to sell and trade it in my local.
Any questions? I need 02-07 wrx/sti motor mounts (no crack), mine got cracked, needs 04-07 sti rebuild complete gaskets & seals set kit, 04-07 sti timing belt kit w/ water pump (pulleys & tensioner), 05 wrx clutch kit, and killer b oil pickup.
Text me 720-334-4935 Duc.
