Results 1 to 7 of 7
This is a discussion on Odd search behaviour within the Website/Forum Support - Report Errors forums, part of the Community - Meet other Enthusiasts category; When searching for the terms KYB AGX I get zero results. Yet the terms appear in many threads (I know ...
    KYB AGX
    I get zero results. Yet the terms appear in many threads (I know from memory).
    Are three letter words excluded from searches and if so, can we have an exception list?
    zax
    zax is online now
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    SD, you must speak your search parameters into the mouse: "Computer, _____"
    In all seriousness, I've noticed the same when recently using the search bar...
    Facebook me here
    So it's a general issue with 3-letter acronyms and such it seems. Neither BOV nor "BOV" return results either. This could become a hassle because people often search specifically for 3-letter acronyms on the site -- and people are often instructed to search for 3-letter acronyms on the site.
    zax
    zax is online now
    Nov 2008
    Yes, the 3-letter acronym seems to define the archetype of this problem. I just tried "KYB GR2" and... nothing. I'm sure someone has discussed KYB GR2s on this site...
    Facebook me here
    Administrator Justin@ClubWRX's Avatar
    Oct 2010
    Irvine, CA
    With the new forum software, vBulletin has completely redesigned the search function and the default minimum character length is automatically set to 4 to prevent a bloated database size. Unfortunately I'm unable to lower that limit. If it's possible for us to change it, I'll have to get Tim's help with it since it has to do with our server settings. I'll talk to him when he gets back from vacation.
    Can you guys make a list of popular 3-letter key words? Lowering the limit to 3 characters will inflate the database a lot so 3-letter searching will need to seem worth it.
    Justin
    justin@clubwrx.net
    ClubWRX.net Admin
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    kyb
    gr2
    aps
    agx
    AP
    WRX
    STi
    RBV
    GPS
    Rim
    Sizes such as: 1" / 2" / 3" / 4" / 2.4" / 1mm 2mm 3mm etc (esp 9mm )
    years such as 02 / 03 / 04 / 05 etc
    HP
    TQ
    EAT
    5MT – Five Speed Manual Transmission
    6MT – Six Speed Manual Transmission
    ABS – Anti-lock Braking System
    AFR (or A/F) - Air to Fuel Ratio
    ALK - Anti Lift Kit
    ALS: Anti Lag System (EM trick to keep the turbo spooled when off the throttle)
    AT – Automatic Transmission
    ATF – Automatic Transmission Fluid
    AWD – All Wheel Drive
    BBK - Big Brake Kit
    BHP – Brake HorsePower (measured BEFORE transmission)
    BOV – Blow Off Valve
    BPV - By-Pass Valve
    CAI – Cold Air Intake
    Cat – Catalytic Convertor
    CBE = Cat Back Exhaust
    CEL – Check Engine Light
    CF – Carbon Fiber
    Cf -- drag coefficient or coefficient of drag (airflow resistance)
    CO2 – Carbon Dioxide
    DP -- Down Pipe
    DC -- Double Clutch
    DRL = Daytime Running Lights
    EBC – Electonic Boost Controller
    ECT - Electronically Controlled Transmission
    ECU – Electronic Control Unit (engine control unit)
    EDM - European Domestic Market
    EFI – Electronic Fuel Injection
    EG – Subaru 6-cylinder engines (up through mid to late 90’s)
    EGT - Exhaust Gas Temperature
    EJ – Subaru 4-cylinder engines (early 90’s and newer)
    EM - Engine Management
    EMS = Engine Management System
    EWG - external wastegate
    EZ – Subaru 6-cylinder engines (post EG series H6 engines)
    FDR - Final Drive Ratio
    FHI - Fuji Heavy Industries
    FWD – Front Wheel Drive
    FSB -- Front Sway Bar
    H4 – Horizontally Opposed 4 cylinder (boxer)
    H6 – Horizontally Opposed 6 cylinder
    HF - High Flow (usually used in conjunction with a catalytic converter)
    HID – High Intensity Discharge (headlights)
    HT-- Heal and Toe
    IC -- Intercooler
    JDM – Japanese Domestic Market
    LHD = Left Hand Drive
    LSD – Limited Slip Differential
    MAF or MAS – Mass Air-Flow Sensor
    MAP – Manifold Absolute Pressure Sensor
    MBC – Manual Boost Controller
    MIL – Malfunction Indicator Lamp (CEL)
    MT – Manual Transmission
    MY – Model Year
    NOS - Nitrous Oxide
    OBD - On Board Diagnostics
    OE – Original Equipment
    OEM – Original Equipment Manufacturer
    OL/CL - Open Loop / Closed Loop
    Pot -- (ie. 4-pot brake) pistons on caliper.
    P&P -- port and polish of cylinder heads to improve airflow.
    PPG -- Pfitzner Performance Gearbox
    RHD = Right Hand Drive
    RPM - Revolutions Per Minute
    RSB -- Rear Sway Bar
    RWD – Rear Wheel Drive
    SOA – Subaru Of America
    SPT = Subaru Performance Tuning
    TDC = Top Dead Center (relative to piston location)
    TBE -- Turbo Back Exhaust
    TGV - Tumble Generator Valve
    TQ - Torque
    TR - Tuner Ready (aka '06 WRX TR)
    TSB - Technical Service Bulletin
    TT – Twin Turbo
    UDP – Under Drive Pulley
    UP -- Up Pipe
    VDC – Vehicle Dynamic Control
    VIN – Vehicle Identification Number
    VTA - Vent to Atmosphere
    VTD – Variable Torque Distibution
    WGA - wastegate actuator
    WHP – Wheel HorsePower
    WOT – Wide Open Throttle
    WRB = World Rally Blue
    WRC = World Rally Championship (competiton or WRC Spec cars)
    Impreza Bodies:
    GF = 5-door Impreza body
    GG = Impreza Wagon
    GM = 2-door (old gen) Impreza body
    GC = 4-door (old gen) Impreza body
    0 = 1.6L (not certain about this one)
    2 = 1.8L
    4 = 2.2L
    6 = 2.5L
    8 = 2.0L
    GD = New Gen Bodies
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    IDE- Injector? Duty? ???
    SRI- Short Ram Intake
    IWG-Internal Waste Gate
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
