Power for your 02-10 WRX or STI! Element Tuning, Invidia, MXP, Cosworth, & more!
Results 1 to 15 of 30
This is a discussion on Power for your 02-10 WRX or STI! Element Tuning, Invidia, MXP, Cosworth, & more! within the Vendor Archived Threads forums, part of the Vendor's Forum category; Read all about this powerful World One built beast here on our new blog: Patrick’s 07 STI – 475 whp ...
    Seattle
    Read all about this powerful World One built beast here on our new blog: Patrick’s 07 STI – 475 whp / 534 wtq on Q16 | World One Performance Blog
    Element Tuning
    Element Tuning GT65 Turbo: $2099 shipped -- 65 lb/min, 400-530whp, Direct Bolt-On
    Quote Originally Posted by Element Tuning
    The GT52 has done so well we figured it was going to be really hard to beat. With that said we are not out to replace it but instead offer something larger for those who are on the edge of purchasing a rotated kit. The biggest difference between the 52 and the 65 would be a more heavily modified Garrett turbine wheel and a 65 lbs compressor wheel stuffed into a 3” compressor cover, a heavily ported 8cm turbine housing, and 19 psi internal gate fitted standard. Unlike the GT52 the GT65 requires TGV deletes and a 3” silicon inlet for installation.
    What to learn more about the GT65? See the dyno plot of it making 512 whp and more. Click Here
    Element Tuning GT52 Turbo: $1899 shipped -- 52 lb/min, 375-500whp, Direct Bolt-On
    This turbocharger is very similar to many other 7cm TD06 20G framed bolt-ons but that's where the comparison ends. In this particular turbocharger we use a Garret GT30R 52 lbs compressor wheel, Garrett turbine wheel and shaft. The compressor is a GT30R rated at 52 lbs utilizing an internal wastegate.
    Typically we see 20 psi by 3600-3800 rpm tuning with the Hydra with pump gas power in the 375-400 whp range. Both housings are completely ported for increased flow and wastegate performance. Race gas power is in the 475-500whp range.
    Expect to achieve full boost with the proper modifications and a quality tune between 3500-4000rpms. Fuel upgrades for this turbocharger and proper engine management are required.
    The Element GT52 has been recently updated to increase internal wastegate performance. Increased port work, larger wastegate port, and a larger wastegate valve has been utilized to ensure boost creep free performance.
    Element Tuning GT49 Turbo: $1699 shipped -- 49 lb/min, 350-470whp, Direct Bolt-On
    The GT49 is based on the Mitsubishi TD06 7cm frame but is modified to accept a Garrett compressor wheel. This turbocharger utilizes a Garrett 49 lbs compressor wheel, and a TD06 Turbine wheel modified for higher flow and creep-free performance. A 2.4" inlet is machined and ported to allow for easier installation and higher performance.
    Typically 20 psi is reached by 3400-3600 rpm tuning with the Hydra and pump gas. Pump gas power is in the 350-375 whp range. Both housings are completely ported for increased flow and wastegate performance.
    Race gas power is in the 450-460 whp range. Expect to achieve full boost with the proper modications and tuning between 3500-3700rpms. Fuel upgrades for this turbocharger and proper engine management are required.
    Other Element Tuning direct bolt-on turbos:
    Element Tuning TD05-18G Turbo: $1295 shipped
    Element Tuning TD05-20G Turbo: $1349 shipped
    Element Tuning TD06-20G Turbo: $1549 shipped
    Element Tuning Competition Forged H Beam Connecting Rods for Subaru EJ20/EJ25: $549 shipped
    Element Tuning's 4340 forged H beam rods are manufactured to the highest standards in the industry. Element Tuning has fully tested these rods in our Time Attack program with exceptional success and performance. Each rod is CNC machined from 4340 steel forgings, shot peened, stress relieved, heat treated, and magnafluxed for uncompromised strength and reliability. Precision machined in the USA to within .0002" ensures exacting fitment and rod length is set to exact OEM specification at 5.137," not shorter like many other rods.
    When it comes to hardware we use the best in the business, ARP. Element rods are assembled using ARP 3/8" 2000 bolts rated at 220,000 psi of tensile strength. Upgrading the OEM STi rods with Element Tuning's 4340 rods is highly recommend when pushing 550+ whp and high rpm applications where the OEM rods can potentially twist.
    Bronze bushed small end with oiling hole. Large and small ends are balanced and come in weight matched sets. At 520 grams including hardware these are some of the lightest rods available for your Subaru.
    Element Tuning Forged 4340 H Beam Rods Include:
    - 4 forged H beam rods weight matched and balanced
    - ARP 2000 rod bolts
    - Installation instructions
    Element Tuning Full 3-Inch Turboback Exhaust for 02-07 WRX/STI: $899 shipped
    The exhaust system is designed to deliver a smooth tuned deep base sound any Subaru Boxer engine lover is sure to enjoy! Critical muffler design and a large straight through resonator provide unrestricted power and flow while keeping sound levels moderate and drone out. For those who want to keep things as quiet as possible a muffler tip silencer is included free with every full exhaust or cat-back system.
    MXP
    Although a relatively new brand, MXP is brought to you by Mackin Industries, the official importer of high end JDM parts such as Volk Racing, Rays Engineering, Advan, ARC, Project Mu, and more. The MXP turboback features SUS304 stainless steel, 77mm (3-inch) piping throughout, a 3-year warranty, and is a complete and easy bolt-on system.
    Videos:
    YouTube - 2008 Subaru STi : MXP Cat Back : Exhaust Clip
    YouTube - 2008 Subaru STi : MXP Cat-Back Exhaust : Driving Off
    Pricing:
    MXP Turboback Exhaust for 08-09 STI: $1599 shipped!
    MXP Catback Exhaust for 08-09 STI: $1224 shipped!
    MXP Catless Downpipe for 08-09 STI: $378 shipped!
    [SIGPIC][/SIGPIC]
    WORLD ONE PERFORMANCE
    Phone: 253.336.5449
    AIM: WorldOneArmin
    World One Performance Blog | Customer/Employee Gallery
    Building Award-Winning Subarus since 2002, with the track record to prove it.
    Quick reply to this message Reply
    Seattle
    Invidia
    Video:
    YouTube - Invidia Q300 Catback for 2008 STI
    Invidia Q300 Catback Exhaust for 08-09 STI: $812.49 + shipping
    Invidia Catless Downpipe for 08-09 STI: $259.99 + shipping
    Invidia Catted Downpipe for 08-09 STI: $454.99 + shipping
    Video:
    YouTube - Invidia G200 Exhaust for WRX/STi
    Invidia G200 Catback Exhaust for 02-07 WRX: $571.99 + shipping
    Greddy
    Video:
    YouTube - Greddy Ti-C Exhaust on STI
    Greddy Ti-C Catback Exhaust for 02-07 STI: $520.70 + shipping
    Greddy Evo 2 Catback Exhaust for 02-07 WRX: $597.78 + shipping
    JIC
    JIC Spartan DE Type 1 SUS Catback Exhaust for 02-07 WRX: $665.28 + shipping
    JIC Spartan DE Type 1 ST Catback Exhaust for 02-07 WRX: $868.56 + shipping
    JIC Spartan DE Type 1 Ti Catback Exhaust for 02-07 WRX: $1680.45 + shipping
    CP Pistons
    CP Pistons Standard Bore for EJ25 Motor, Set of 4, 99.5mm Bore / 8.2 Compression: $509 + shipping
    CP Pistons .5mm Overbore for EJ25 Motor, Set of 4, 100mm Bore / 8.2 Compression: $509 + shipping
    Cosworth
    Cosworth Camshaft Set for Subaru WRX STI EJ257B (Dual AVCS) S2D Grind : $1235 shipped
    Cosworth Camshaft Set for Subaru EJ20 North American Spec 2.0L: $993 + shipping
    Cosworth Camshaft Set for Subaru EJ25 North American Spec 2.5L S2 Grind: $1098 + shipping
    Cosworth Camshaft Set for Subaru EJ25 North American Spec 2.5L Standard Grind: $1098 + shipping
    Turbosmart
    Turbosmart Ultra-Gate 38mm External Wastegate: $249 shipped
    Not seeing what you need above? Please feel free to send us a PM or send us an e-mail through the website here:
    Can't find the product you're looking for?
    World One is an authorized dealer for each of the above brands and more! We are adding more and more new products to our website catalog every day, so please check back for updates!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Humpday bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Thursday bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    TGIF bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    MUNday bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Tuesday bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Humpday bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Thursday bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    TGIF bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Last day of August bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    September bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Humpday bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Thursday bump!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
    Seattle
    Labor Day Weekend FREE SHIPPING Website Specials! Use Coupon Code "LABORDAY" at checkout to receive free shipping!
    [SIGPIC][/SIGPIC]
    Phone: 253.336.5449
    AIM: WorldOneArmin
