Grimmspeed 38mm Tial MVS Up Pipe Group Buy!
Results 1 to 6 of 6
This is a discussion on Grimmspeed 38mm Tial MVS Up Pipe Group Buy! within the Vendor Archived Threads forums, part of the Vendor's Forum category; We know many of you have been yelling at us to get this thing started, we'll now’s the time. This ...
    Nov 2007
    Plymouth, MN
    We know many of you have been yelling at us to get this thing started, we'll now’s the time. This is the product release group buy for our new 38mm EWG Up pipe.
    An External Wastegate (EWG) allows exhaust gases to be diverted prior to entering the turbo; thus creating a quicker turbo spool. GrimmSpeed’s EWG has a larger diameter than the stock internal wastegate; this allows the exhaust gas to be released faster, which improves boost control, maintains maximum boost longer in the rpm range and extends the life of the turbo. Moving the wastegate out of the turbo relieves the turbo from the massive amounts of turbulence that the stock internal wastegate creates.
    GrimmSpeed’s EWG Up-Pipe is built from 304 SS with very thick 13mm 304 SS flanges that will not warp. The flanges have been CNC cut for precise tolerances(no laser cutting here!). A flex section has been added; this will extend the life of the product(allows expansion/contraction of pipe without cracking) and will lead to less exhaust leaks. Users should expect gains in the 15-40hp range when tuned for the EWG set-up.
    Also included in the EWG Up-Pipe package, a bracket to hold the stock internal wastegate shut. This bracket is helpful because the turbo door does not need to be welded shut, decreasing the chance for leaks and allowing for easy removal if necessary.
    The GrimmSpeed EWG Up-Pipe Kit fits more downpipes than any other EWG Up-Pipe on the market.
    Quick Facts:
    Quality Flex Joint - We've sold well more than 600 pipes with flex joints and have never had an issue with any stock grimmspeed pipe.
    Flow through Flex - There are no big steps in the flow path of our flex joint. Our flex is not located on a bend so there is very minimal flow loss(if any) through the flex.
    EWG Side Outlet Support - Our ewg up pipes come with an extra support on the external wastegate outlet of the pipe so you can have no worries about failure.
    2.0mm Piping Thickness - almost all pipes on the market use a 1.5mm thick piping wall, not us. We use a 2mm thick piping wall(33% thicker than all of our competition!)
    Pipe to Flange Connection - Much smoother connection. Piping is ported flush with flange so there is no step into the pipe.
    1.92" Inlet = perfect match to gasket allowing a little room for gasket movement(anything bigger, ie 2", will almost be guaranteed to put the gasket in the flow which is horrible for flow)
    1.75" Outlet = Narrowing down from 1.92 to 1.75 acts as a funnel. Also very close match to most common turbos so you have much less step going into the turbo(unlike a straight through 2" which creates a huge step going into most common turbos vf's, tdo4s, etc)
    Massive 304SS flanges
    15+whp gain
    Minimal internal steps for maximum flow
    Complete stainless steel construction(pipe, flex section, flanges)
    Flex joint that is NOT located in the bend which adds life expectancy to the flex section. Many other up pipes have a flex right in a sharp bend so all the exhaust/turbulence is hitting up against it.
    Reduce turbo lag
    Increase exhaust flow to turbo
    GROUP BUY DETAILS
    Closes on: Tuesday, June 30th(2 weeks long)
    Participant limit: First 25 will ship right away, anyone after 25 there will be a delay in shipping
    Pricing structure: Tiered
    Normal MSRP: 319.99
    1-10 participants: 299.99
    11-20 participants: 279.99
    21+ participants: 259.99
    Shipping will be $10 to anywhere in the 48 states. International shipping will be extra.
    Add-Ons
    GrimmSpeed Thermal Coating: $29.99 (coating on both up pipe and dump tube)
    Tial 38mm V-Band Wastegate: $240.00
    GrimmSpeed 3-Port Boost Solenoid: $99.99 (highly recommended for EWG setup)
    GrimmSpeed Manifold > Up Pipe Gasket: $11.99
    GrimmSpeed Manifold > Up Pipe 2x Thick Gaskets: $17.99
    GrimmSpeed Up Pipe > Turbo Gasket. $12.99
    IWG Bracket Options
    TD04
    VF Series
    FP Green/Red 3” Inlet only
    FP18G
    Blouch 20G
    Turbochargers.com 18G
    SB GT14
    PARTICIPANT LIST:
    1.BreaknLoose
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    11.
    Package Contents:
    (1) GrimmSpeed 38mm V-Band EWG Up Pipe
    (1) GrimmSpeed 38mm V-Band Dump Tube
    (5) Top Flange Studs
    (2) Bottom Flange Bolts/Nuts
    So if/when we get to the best pricing tier, you are looking at $499.99 for a 38mm VBand Up Pipe AND a Tial 38mm Wastegate....now THATS a heck of a steal!!
    Modern Automotive Performance
    P: 763-545-3800
    E: Dave@maperformance.com
    W: www.maperformance.com
    AIM: Davidjatmap
    Quick reply to this message Reply
    Nov 2007
    Plymouth, MN
    Bump!
    P: 763-545-3800
    AIM: Davidjatmap
    Nov 2007
    Plymouth, MN
    Bump!
    P: 763-545-3800
    AIM: Davidjatmap
    Nov 2007
    Plymouth, MN
    Bump! Only a few days left!
    P: 763-545-3800
    AIM: Davidjatmap
    Nov 2007
    Plymouth, MN
    Bump!
    P: 763-545-3800
    AIM: Davidjatmap
    Nov 2007
    Plymouth, MN
    Bump! Last day to get put on the list!
    P: 763-545-3800
    AIM: Davidjatmap
