Results 1 to 10 of 10
This is a discussion on GrimmSpeed Divorced Downpipe - Product Release Group Buy within the Vendor Announcements forums, part of the Vendor's Forum category; Guys and gals, I'm extremely excited to be announcing this long time coming product. Over the last few years we ...
    ClubWRX.net Vendor
    May 2007
    St. Paul, MN
    Thumbs up GrimmSpeed Divorced Downpipe - Product Release Group Buy
    Guys and gals, I'm extremely excited to be announcing this long time coming product. Over the last few years we have had TONS of you asking for us to create a top-of-the-line downpipe...something that blows everything else out of the water.
    Well....(watch the story)
    USA's Finest Downpipe. No expense spared.
    • Materials, Fabrication, Design... all pure USA.
      (Keeping jobs in the USA is one of our primary team missions)
    • Innovative 3-D Contour Flange
    • FARO™ Arm Designed
      (We are at the leading edge of new product design hardware)
    • CNC Mandrel Bent Tubing
      (We have created custom CNC bend-dies to ensure best flow through pipe)
    • Flanges FULLY CNC Machined
      (All 3 sides. Check our our competitors nasty laser cut-only flanges)
    • Divorced Wastegate for Optimal flow
    • GrimmSpeed Gasket Set Included
    We are extremely proud to introduce our Catless Divorced Downpipe for Subarus. It's safe to say, the years our engineering department spent on this downpipe have paid off. A GrimmSpeed™ Catless Divorced Downpipe is one of the first modifications that should be done on your car. The OEM downpipe contains two very restrictive catalytic converters, killing the power potential of your car (not to mention the oem blocked wastegate port).
    You are looking at a top-of-the-line fully USA built Downpipe. All materials, engineering, R&D, fabrication, etc are straight out of the USA. The tubing is CNC Mandrel Bent 304 Stainless Steel using our custom made bend dies which give you the best fit and performance possible. Please take a second to check out these 304 Stainless Steel flanges...a serious work of art. All 3 sides of the flanges are CNC Machined to perfection. If that isn't over-the-top enough for you, check out the new 3-D Contour Flange. Instead of the exhaust hitting a flat wall like on most divorced downpipes, we have spent a lot of engineering(and machining) hours creating a nice smooth transition through the wastegate port for the ultimate in boost control for you. The outlet of the downpipe has a standard 3” 2-Bolt flange that will mate up with most aftermarket cat-backs on the market. We have also included a wideband O2 bung for you if needed. Having a secondary o2 Bung saves you time and money because you will not have to pay a shop to install one for you.
    FARO™ Arm for perfection. During our design, we utilize our in-house 7-axis FARO™ Arm to obtain extremely accurate fitments. What this means is, we scan all of the mounting points on the car, bring those into our CAD software, and then begin designing the pipe around our scanned oem data in our Solidworks CAD software. Most downpipes(or exhaust pipes for that matter) on the market are designed using fixtures. Essentially our competitors will create a welding fixture by hand off of an oem part. This leads to a ton of chances for things to be off. We don't take those chances. We have spent the capital on R&D equipment where others have not.....for you.
    By using a downpipe that is catless, it allows you to fully maximize your exhaust flow which will increase the ability of your car to produce huge horsepower and torque gains. Turbo power, response, and efficiency is greatly improved. Once you have added our downpipe to your vehicle, you must be tuned.
    Replacing your factory catalytic converter sometimes causes a ‘cat converter efficiency’ check engine light. You can either use tuning to delete this CEL or you can use a mechanical fix.
    Going over-the-top, it's what you can expect from GrimmSpeed™
    More pictures and info here:
    GrimmSpeed
    Fitments:
    Subaru WRX 02-07
    Subaru STI 02-07
    GROUP BUY DETAILS
    Closes on: Friday, November 30th.
    Participant limit: Unlimited
    Pricing structure: Tiered
    The Group buy will last 2 weeks.
    Normal MSRP: $499.99
    1-10: $459.99
    11-20: $429.99
    21+: $399.99
    Shipping is $25 to anywhere in the US. International is extra depending on location.
    PARTICIPANT LIST:
    1.
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    GrimmSpeed
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    Any plans for the GR Chassis?
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    ClubWRX.net Vendor
    May 2007
    St. Paul, MN
    Quote Originally Posted by maus View Post
    Yup
    GrimmSpeed
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    any plans for one without the wastegate returning?
    i'm going ewg, so won't need that.
    Registered User Terminal Kuz's Avatar
    Aug 2012
    SoCal
    Man i want this so bad but already have a DP. Why couldnt you have this ready like 2 months ago lol.
    2005 WRX (Silver) SoCal Subie
    Blobeye Syndicate #1093
    http://www.clubwrx.net/forums/builds...al-05-wrx.html - Build Thread
    http://www.flickr.com/photos/34009765@N06/ - For whatever pics i take.
    Mikie13-Spend money on hookers and blow. That's a better intake.
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Plans on adding a cat? Cats are good.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Mt. Laurel, NJ
    Jesus this is beautiful! I can't justify spending $400+ on a catless DP when the one on my car was given to me for free
    Best of luck with the sale, and hopefully I'll be able to grab one some day!
    Have you considered making an EWG downpipe? One similar to the HKS flat-plate design.
    ClubWRX.net Vendor
    May 2007
    St. Paul, MN
    Quote Originally Posted by shadowpr View Post
    No plans right now, we wanted to keep the divorced tube on there so you can switch setups and not have to worry about a new downpipe.
    Quote Originally Posted by Terminal Kuz View Post
    I'm sure you could sell your other one on the forums
    Quote Originally Posted by Sasquatch View Post
    Down the road, definitely.
    Thank you. Can't argue with free!
    Justin
    GrimmSpeed
    May 2010
    Pittsburgh, PA
    This.
    The down pipe looks fantastic... but trying to torque even my bellmouth downpipe down with the EWG in the way is extremely difficult. I would switch to a catless downpipe with a flat flange vs. my bellmouth no questions asked.
    That being said, I understand why a particular manufacturer would make a bellmouth - the flat flange is a niche. The niche hasn't been filled yet for GRs though
    2011 STi Build Log
