This is a discussion on GrimmSpeed Adjustable Wastegate(IWG) Bracket - PRODUCT RELEASE within the Vendor Announcements forums, part of the Vendor's Forum category; http://www.grimmspeed.cm/catalog/product_info.php?cPath=22&products_id=251 Product Release Day! Introducing our brand new Adjustable Wastegate(IWG) Bracket. Years ago we were the first company to bring ...
Years ago we were the first company to bring Internal Wastegate Brackets to the Subaru market(on a large scale). Since then we have made about 15 different bracket designs to fit various turbos in the market. We've come to the realization that we can't continue producing large numbers of random turbo fitments each year so we have decided to make a kick butt adjustable bracket that will fit a large majority of all turbos. We spent the last year and a half testing this bracket on tons of turbos to assure we can hit as many turbos as possible as far as fitment is concerned.
Enjoy!
Justin Grimm
- Fits Most Turbos!
(1 1/2 years of testing fitments of turbos)- Stainless Steel Construction
- Laser Engraved GrimmSpeed Logo
- Fully Adjustable Rod
(Allows it to fit more turbos)- Simple and attractive allen head bolt
- Seals Wastegate door tightly
(No "hardware store" washers and nuts)
The internal wastegate(IWG) bracket is used in place of the stock wastegate actuator when moving to an external wastegate setup. In previous years, Subaru owners had to weld the IWG shut on their turbos which diminished resale value, had the chance of cracking, and made it very difficult to revert back to the stock IWG setup.
We are bringing you the solution to this problem, the IWG bracket. This is a basic bolt-on which takes 5 minutes to install. No more worrying about the wastegate door opening due to a cracked weld, no more worrying about trying to sell your turbo with welding all over the wastegate door. Feel like reverting back to stock?...simple, just unbolt the bracket and you are good to go.
The reinvention of utility, it's what you can expect from GrimmSpeed™
Fitments:
Most turbos (Excludes VF series turbos, we have a specific bracket for VF turbos)
Click here to buy
GrimmSpeed
