Looking to buy a 2015 STI in the coming months, and debating whether or not to keep my car or sell it. This is solely gauging interest...
Two options...purchase as-is or part-out and sell stock.
Year: 2005
Mileage: 110K
Color: PSM
Modifications that I'm willing to let go with the car are as follows...
Invidia V2 Downpipe
Grimmspeed EWG UP + Tial 38mm V-Band EWG
Grimmspeed 3-port BCS
Ported/Polished Exhaust Manifold and Crosspipe
APS 65mm Cold Air Intake
Walbro 255lph GSS342 Fuel Pump
OpenECU Reflash
Turn-In Concepts Fender Cowl Braces
Whiteline KCA359 Anti-Lift Kit (Sport)
Whiteline 24mm Adjustable Front Sway Bar
Whiteline 22mm Adjustable Rear Sway Bar
Kartboy F/R Endlinks
GTWorx GD-style Camber Plates
RCE Black Springs
Camber Bolts (Rear)
Group-N Engine Mounts
Group-N Transmission Mount
Kartboy Standard Exhaust Hangers (x3) / Extended-Length Exhaust Hanger (x1)
Kartboy F/R Shifter Stay Bushings
Turn-In Concepts Shift Linkage Bushings
Turn-In Concepts 6MT Pivot Bushings
Turn-In Concepts Transmission Crossmember Bushings
Turn-In Concepts Rear Differential Mount Bushings
Kartboy Rear Subframe Outrigger Bushings
Kartboy Subframe Lock Bolts
25% Rear Window Tint
IxizConcept Hood Dampers
Hella Supertones
Up-to-date service intervals
Engine Oil: Shell Rotella T6 5W40
Engine Oil Filter: Purolator PureONE (PL14612)
Fumoto Oil Drain Valve
Low-Beams: Phillips D2R (85126)
High-Beams: Phillips 9011 (HIR Mod)
Map/Dome Lights: SuperBrightLEDs 3022-CWHP4
Reverse Lights: SuperBrightLEDs 7440-W18-T
Battery: Optima Red Top (Group 35)
Wipers: PIAA Super Sporza Silicone 22" | PIAA Super Silicone 17" | Rain-X Original Window Treatment
Transmission Fluid: Subaru Extra-S 75w90
Rear Differential Fluid: Subaru LSD 90LS
Coolant: 1gal Subaru "Long Life" Coolant / 1gal Distilled Water
Washer Fluid: Rain-X 2-in-1 Windshield Washer Fluid
Price: $18K modified / $16K stock
