For Sale 2011 WRX Premium SWP 28K miles, $30K invested, ETS3076R, Rallispec 6-spd, BBK, $18K
Results 1 to 2 of 2
This is a discussion on 2011 WRX Premium SWP 28K miles, K invested, ETS3076R, Rallispec 6-spd, BBK, K within the Vehicles for sale forums, part of the Marketplace category; Well time to sell the car 28K miles, engine is fully built but does have low compression drives and runs ...
    Dec 2010
    Well time to sell the car 28K miles, engine is fully built but does have low compression drives and runs fine, needs new rings, car will come with a 2012 LB that had a ring land failure and needs rebuild will include all other parts from build multiple silicone fittings, intakes, motor parts, sensors etc.
    VIN# J1G769BG815825
    SB - Eagle H-beams, Weisco stnd. bore pistons, ACL race bearings, main & rod, 701 series block, ARP head studs. Custom 42draft designs Catch Cans, Grimmspeed AOS(in box). AP ELH, ARK Grip CBE, FIC 900CC Inj. / AP fuel rails / Russell lines and fittings, 255 lph Aeromotive pump, Fuel Lab FPR, Process West FMIC piping cold side, Custom Hot side, AP speed density tuned, Turbo Smart 50MM BOV, BNIB Fluidampner, AEM MAp Sensor, Grimmspeed EBC, Perrin Alt & Radiator covers
    Heads - Stock decked and cleaned, gone though
    Trans - Rallispec 6-spd swap, HDSS clutch kit, Group-N trans mount, SS bushings
    Turbo - ETS rotated kit GTX3076R, ETS 4" FMIC
    Meth - Aquamst HSF-3 w/remote tank
    Brakes - ISC BBK front 6-pot w/race spec floating 2pc. rotors, FHI rear 2-pot w/KNS adapter & DBA slotted rotors
    Wheels / Tires - Rota T1R / Khumo Ecsta 4x 265-35-18
    Suspension - ISC Street Spec coils w/rear extensions, Perrrin Front/Rear sways, AVO end links, Ultimate Racing strut bar, ISC rear LCA's, Various white line bushings, stiffeners, Beat rush trans isolators
    Interior - GT spec leather/carbon wheel, Redline Goods shifter, brake and center console covers, SMY cluster w/Depo racing EGT/Boost gauges, Solid Mods vent pod w/Innovate AFR gauge, Alpine full system w/Navigation, INAW910, PDX V9 (1000W), PXA-H800 DSP, CDT front stage, Alpine Rear Stage, JL 10W3V3 w/perfect fit sub box, CHA-634 changer, TMW SS, Dynoc wrapped interior pcs., All Weather matts
    Exterior - Bayson full bottom line CF lip kit, rear CF diffuser, Rear CF wing extension, Rear JDM mid wing, WRX black garnish plates, Depo headlights w/Mach-V LEDs, STI heated mirrors, Rear Reflector LEDs
    2012 LB dissembled, Crank, Rods, Block halves 704 series, B25 Heads, cams, various Silicone couplers, Vibrant silicone hose, fittings, sensors, Extra ETS intake, Isovibe mounts, Meth lines & nozzles, PW Silicone FMIC couplers, Some stock parts, MAF sensor, turbo fittings spacer plate, BNIB ISC front & rear replacement dampeners, on and on
    Feb 2010
    Depsoit taken on care, will update
