For Sale 2002 WRX - vf39, 6-speed - NY
Results 1 to 4 of 4
This is a discussion on 2002 WRX - vf39, 6-speed - NY within the Vehicles for sale forums, part of the ClubWRX.net Marketplace category; Fayetteville NY, {Syracuse Area} 00 Summary 2002 WRX VF39, FMIC, 05 STi 6-speed, suspension mods, etc Passed NY inspection on ...
    Feb 2007
    Central, NY
    $8500
    Summary
    2002 WRX
    Passed NY inspection on 9/10/2013
    125-130k mi. The original odometer **** the bed, so am going by what the previous owner told me when i bought it and carfax {reputable guy from CNYsubars.com}
    2011 = new clutch, flywheel, IACV
    2012 = TB job, accessory belts, water pump, thermostat, tranny fluid with extra-S
    2013 = Rear brakes upgrade, new struts, new tires, front o2 sensor
    The deets.....
    Engine
    Turbo XS UTEC Engine Management
    LC-1 Wideband o2 {needs to be replaced}
    Header / Uppipe combo
    Turbo XS Downpipe with high flow cat
    Custom Midpipe
    Cobb Axleback
    Walboro 355 Fuel Pump
    550 JDM STi Pinks
    VF-39
    Turbo XS manual Boost controller
    Turbo XS FMIC
    SPT Short ram intake, K&N Filter
    Turbo XS h34 BPV
    Drivetrain
    05 STi 6mt
    R180 Rear Diff
    Driveshop.com Level 5 axles
    STi Driveshaft
    B&M Short throw shift kit and bushings
    Exterior
    Ebruni Grill
    Blue “I” impreza badge
    Home made eyelids {Already have 1 replacement headlamp w/o eyelid}
    Aluminum scoop delete {Stock scoop included}
    Rota Boost 17x8 +44
    Hella Supertones
    04 WRX taillights
    Uhaul trailer hitch {not installed}
    Prodrive Replica front lip
    Painted side skirts
    Rally Armor mudflaps – Black with red lettering – uninstalled for summer
    Interior
    Ver7 STi gauge cluster
    Omari 52mm boost, EGT, Oil pressure gauges {only Oil Press currently installed}
    JVC headunit
    Pioneer Front Speakers
    JL 12” sub w/ JL amp under drivers seat
    Custom Wrapped door cards in matching red
    2004 WRX seats
    Suspension/Handling
    Tein S-tech springs
    KYB struts
    Hankook Ventus V12 evo 235/45/17 ~1000 miles
    Hardrace rear endlinks
    front strut bar
    Rear strut bar
    Ladder brace
    H6 rear brake upgrade
    Good
    Clutch / Flywheel replaced 10k miles ago
    H6 rear brake upgrade = new calipers, brackets, rotors, pads = April 2013
    Tires replaced late May 2013
    Timing belt, water pump, access belts, thermostat all done Summer 2012
    Front Pads replaced in July 2013
    Extra-S gear oil changed maybe 7500 miles ago
    New Struts August 2013
    New IACV about 10k miles – a common issue part for 100k mi WRXs
    Mechanically reliable. Been my DD for 3 years.
    Car from NC, been in NY maybe 5-6 years. 2-3 of which the previous owner spend most of the winter in Iraq
    Bad
    Rear passenger switch doesn’t put the window up. {driver can}
    Window Tint has seen better days
    Auto-Dimming mirror doesn’t auto dim and has yellow circle, compass still works
    Front grill fastening tabs broken.
    Under tray a little beat as is the passenger fender liner.
    Paint is far from perfect as the car has 120k miles on it but no-to-very minimum body rust.
    Unknown dig in the rear bumper, and spot on front bumper from hit-and-runs
    FMIC paint a little chipped
    Notes / includes
    There was a gauge pod which housed the Oil, Boost, and EGT where the clock is on the dash.. I didn’t like the pod nor was I modding the engine anymore, and it runs great, so I removed the pod, and put the Oil pressure in the corner. All the connections were left in place, and tucked in the dash for easy reinstall, or even quick install for diagnosis. When these were installed they hacked the connector off for the OEM clock pod, so right now it displays nothing.
    Also has a remote starter. I have the hood scoop, and 1 headlight which I was searching craigslist for another one because I wasn’t a huge fan of the eyelids. Touch up paint, plus 3x 30% full cans of color matched spray used for the skirts and lip.
    Feb 2007
    Central, NY
    Feb 2007
    Central, NY
    bump...
    Feb 2007
    Central, NY
    Sold
