Results 1 to 2 of 2
This is a discussion on NC: 08 STI 6MT w/ RalliSpec block and TopSpeed tune, Aspen White, 70K highway miles within the Vehicles for sale forums, part of the ClubWRX.net Marketplace category; I'm selling my pride and joy to get a bigger kid/family friendly car (hopefully an SUV). I'm actually doing this ...
    Nov 2010
    SOLD NC: 08 STI 6MT w/ RalliSpec block and TopSpeed tune, Aspen White, 70K miles
    I'm selling my pride and joy to get a bigger kid/family friendly car (hopefully an SUV). I'm actually doing this sooner than I originally intended since I recently broke my leg pretty bad from playing sports and won't be able to drive my car for at least 4 months while it fully heals...
    I'm located in the Triangle area (Raleigh, Durham, Chapel Hill).
    2008 Subaru Impreza WRX STI, Aspen White, Hatch (5 door)
    Mileage: ~71,500 (Mostly highway)
    New RalliSpec short block installed Summer of this year after running into the infamous ringlanding issues with the stock block.
    Since the engine was being replaced I went ahead and had the following new major parts replaced and installed:
    -New clutch system (disk, pressure plate, flywheel)
    -New oil system (oil pump, oil pan)
    -New belts and pulleys (timing belt, accessory belt, AC belt)
    I also had new brake pads and tires installed a month ago.
    See full list of modifications below.
    So the car is newer, stronger, and better than ever. I also take great care of the car and only took it to one track event since I had the car (no auto-cross or drag events). The car is reliable, very fun to drive, and definitely one of a kind.
    SOLD
    Contact me for details. Serious inquiries only. Thank you
    MODIFICATIONS:
    Engine
    • RalliSpec Street Spec Short Block (Cosworth forged pistons, Manley 4340 steel H-beam conrods, factory nitrided crankshaft, King uprated main and rod bearings. 8.2:1 CR with EJ257.) *Done in Summer 2012*
    • ARP Head Stud Kit 11mm *Done in Summer 2012*
    • PERRIN Performance One Piece 3" Highflow Catted downpipe
    • Grimmspeed Electronic Boost Controller Solenoid *Done in Summer 2012*
    • Grimmspeed Air Oil Separator*Done in Summer 2012*
    • NGK Iridium Spark Plugs One Step Colder 2309 *Done in Summer 2012*
    • Grimmspeed Uppipe *Done in Summer 2012*
    • Greddy Racing Ti-C Cat Back Exhaust*Done in Summer 2012*
    • AEM Cold Air Intake Red
    • COBB Tuning AccessPORT V2 (Protuned by Doug at TopSpeed) *Done in Summer 2012*
    • Full TGV Deletes *Done in Summer 2012*
    • SuperTech Viton Seals *Done in Summer 2012*
    • Killer B Ultimate Pickup *Done in Summer 2012*
    • Killer B Performance Oil Pan *Done in Summer 2012*
    • Killer B Oil Baffle/Windage Tray *Done in Summer 2012*
    • SPT Engine Mounts
    • SPT Battery Hold Down (Blue)
    • Torque Solution V3 Billet Pitch Stop Mount *Done in Summer 2012*
    • Gates Racing Micro-V Accessory Belt (Blue) *Done in Summer 2012*
    • Crawford Performance TMIC Air Oil Seperator Black (V2) *Done in Summer 2012*
    • Gates Racing Timing Belt Kit (w/ Water Pump, Idler Pulleys, Tensioner) *Done in Summer 2012*
    • PERRIN Performance Radiator Shroud (Red)
    • SPT Oil Cap (Blue)
    • PERRIN Performance Turbo Inlet Hose (Black)
    • Grimmspeed Phenolic Thermal Spacer 8mm *Done in Summer 2012*
    • Carbign Craft Carbon Fiber Alternator Cover
    • m20 Sandwich Adapter (For oil pressure sensor in oil filter) *Done in Summer 2012*
    • Air Pump Delete (KSTech Air Pump Delete Plate Set) *Done in Summer 2012*
    Drivetrain
    • ACT StreetLite Flywheel
    • TWM Performance Short Shifter (w/ Polyurethane Front & Rear Stay Bushings)
    • ACT Heavy Duty Pressure Plate SB4
    Suspension
    • BC Racing BR Series Coilover Kit Track
    • Whiteline Front Sway Bar 24mm Adjustable
    • Whiteline Rear Sway Bar 24mm Adjustable
    • Cusco Front Strut Tower Bar Type OS
    • Kartboy Front Endlinks
    Brakes
    • Carbotech XP12 Brake Pads (Front) *Done in Sept 2012*
    • Carbotech XP10 Brake Pads (Rear) *Done in Sept 2012*
    • StopTech Stainless Steel Brake Lines Front
    • StopTech Stainless Steel Brake Lines Rear
    Exterior
    • JWM LED License Plate kit (White)
    • Perrin Super Shorty 2" Antenna
    • De-badged hatch ("STI" remains)
    • Vinyl red tail lights (cutout)
    • Rally Armor Urethane Black mudflaps (red letters)
    Interior
    • CG CG-Lock Seatbelt Enhancer
    • WC Lathe Werks STi SI Drive Dial (Blue/Bronze Fade Titanium)
    • WC Lathe Werks Titanium STi Sphere (Blue/Bronze Fade Titanium w/ four grooves on bottom half)
    Wheels/Tires
    • Prodrive GT1 Wheel 18x8.5 (5x114.3 +53mm Gloss Black)
    • Direzza Sport Z1 Star Spec (245/40R-18 Front and Rear) *Done in Sept 2012*
    • Project Kics R40 Neo Chrome Extended Lug Nuts (16+4 Locking, 12 x 1.25mm)
    Electrical and Lighting
    • AEM UEGO Wideband Controller AFR Gauge
    • Autometer Auto Meter Digital Pro Shift Systems L3 Tube Shift Light & Digital RPM
    • Defi Advanced BF Oil Pressure Gauge (Blue 60mm) *Done in Summer 2012*
    • Defi Oil Temperature sensor kit (for Advance ZD) *Done in Summer 2012*
    • Defi Advance ZD OLED Display *Done in Summer 2012*
    • Lightwerkz 6000K Xenon HID (35W D2S) *Done in Summer 2012*
    • DIY Lightwerks CCFL Angel Eyes Kit (100mm)
    • JCS Triple A-pillar gauge pod (Dark Grey 60mm) *Done in Summer 2012*
    • Defi Advanced Gauges Control Unit *Done in Summer 2012*
    • Defi Advanced BF External Gas Temperature (Blue 60mm) *Done in Summer 2012*
    • Defi Advanced BF Fuel Pressure Gauge (Blue 60mm) *Done in Summer 2012*
    • SPT Boost Gauge
    • Hella Supertone Horn Kit Pair
    • HKS Type-1 Black Turbo Timer Blue Back Light *Done in Summer 2012*
    • SMY ClusterMaker Dual Gauge Pod 52mm (Dark Grey) *Done in Summer 2012*
    Nov 2010
    Price dropped significantly to help sell before Christmas.
