For Sale 2002 FULLY BUILT WRX RACER
Results 1 to 15 of 22
This is a discussion on 2002 FULLY BUILT WRX RACER within the Vehicles for sale forums, part of the ClubWRX.net Marketplace category; Up for sale is my 2002 World Rally Blue Pearl WRX. First let me start off by saying this car ...
    Aug 2008
    Kennett Square, Pennsylvania
    Up for sale is my 2002 World Rally Blue Pearl WRX. First let me start off by saying this car has been extremely meticulously maintained by a Factory trained Subaru tech. The car gets driven about 1000 miles a year, with my new job I barely have time for it anymore which is what is prompting the sale. Waxed weekly, the vehicle has seen rain twice since my ownership. The vehicle body has 85,000 miles, the Transmission has about 300 miles, and the motor has about 15,000 miles. As of right now the car makes around 600 HP at the motor at about 30 PSI with the alcohol injection, that being said I will list the extensive list of modifications....All Modifications have been professionally done...
    ENGINE:
    Brand New from Subaru EJ257 STI block and crankshaft
    Forged Eagle H-beam cromoly ESP rods
    Arias forged Pistons
    ARP head studs and rod bolts
    Cometic Head Gaskets
    Heads have been ported and polished and have a 5 angle valve job with blended bowls.
    BRAND NEW NGK 3 steps colder spark plugs
    TGV deletes
    Hondata Intake manifold gaskets
    Walbro 255 lph Fuel pump
    Custom 800cc fuel injectors
    Aeromotive Red billet fuel rails
    Custom fuel system with marshall fuel PSI gauge
    Custom welded oil catch can ( recirculates back into the motor )
    AR Fabrication custom radiator cooling plate
    Front mount oil cooler
    TURBOCHARGER/INTERCOOLER/EXHAUST/ ALCOHOL INJECTION:
    Garrett Precision GT32S Turbocharger
    Precison AS1025 Front Mount Intercooler
    Custom 2.5 in. hot side intercooler piping
    Custom 3.0 in. cold side intercooler piping
    Vibrant performance intercooler couplers with T-Bolt clamps
    Custom 3.0 in. cold air intake with BRAND NEW cone filter
    Tial 46mm wastegate ( vented to the atmosphere )
    Tial 50mm Blow off Valve
    Grainger Manual boost controller
    IR boost control solenoid
    AEM alcohol Injection installed with large nozzle for over 600 HP
    AEM alcohol controller
    Custom rotated up pipe
    3.0 in. downpipe ( v-banded at the turbo )
    3.0 in. QTP electric cutout
    3.0 in midpipe to a magnaflow muffler
    stainless steel turbo oil feed line
    TRANSMISSION/ CLUTCH:
    BRAND NEW ACT 6 puck sprung race clutch
    BRAND NEW ACT race pressure plate
    FULLY BUILT PPG GROUP N 5 GEAR STi CLOSE RATIO STRAIGHT CUT GEARBOX ( DOGBOX ) BUILT IN 6 SPEED CASE WITH LOCKOUT REVERSE AND ELECTRIC CENTER DIFF.
    Front LSD ( Limited Slip Differential )
    NEW STi shifter assembly
    NEW Mobil 1 75w90 fully synthetic gear oil
    INTERIOR:
    Autopower 6 point welded roll cage
    Push button ignition system
    Factory 6 disc in dash cd changer
    PDX tuning wideband Air/Fuel gauge
    Prosport Coolant temperature gauge
    Prosport Boost gauge
    Prosport Oil pressure guage
    Prosport exhaust temperature gauge
    Prosport oil temperature gauge
    ( Gauges are housed in an ATI gauge pod on top of the dash)
    Custom PDI Tuning Switch
    SUBARU All-weather floor mats
    AC/DC power inverter
    EXTERIOR:
    Entire Car is professionally debadged
    BRAND NEW World Rally Blue Pearl Paint job
    Custom black mesh grill
    blacked out headlight housings
    Bi Xenon HID kit
    Black Lower front lip
    STi foglight covers
    Rota BOOST Rims wrapped with Fierce UHP tires 245/40ZR17.
    Goodridge stainless steel brake lines
    painted front calipers
    vehicle is lowered on tanabe DF210 springs
    The rear seat has been removed for weight reduction. I will include this plus the original world rally blue pearl rear wing in case the new owner decides to install.
    Front brakes have about 90% life remaining and the rear brakes also have about 90% remaining, the tires have over half there life left. This car still has the Air conditioning retained and it blows ICE COLD. This car is in phenomenal shape. Please dont hesitate to contact me with any questions. Send me a private message or please text/ call me at 484 888 0268. Thanks for your interest- A.J
    FOR SALE BEST OFFER!
    Attached Thumbnails Attached Thumbnails IMG_20110607_193858.jpg   IMG_20110607_193841.jpg   IMG_20110607_193807.jpg   IMG_20110607_194013.jpg   IMG_20110607_193920.jpg
    Jul 2004
    Seattle, WA
    Hey EvoEatr,
    You're going to catch some flack from calming your car can achieve 600hp with it's current turbo and 800cc fuel injectors. Even with water injection. Do you have a Dyno sheet?
    Who did the tune?
    What kind of ECU is it using (custom tuned stock or standalone)?
    Is more than one map included (Different PSI, Race fuel, valet)?
    Edit: Are any of the stock parts included (headlights/tail lights)?
    Is a shift knob included?
    Is the rear seat included? Seatbelts?
    Aug 2008
    Quote Originally Posted by SeattleJeremy View Post
    Hey EvoEatr,
    You're going to catch some flack from calming your car can achieve 600hp with that small of a turbo, and only 800cc fuel injectors. Even with water injection. Do you have a Dyno sheet?
    Who did the tune?
    I did the tune, stock ECU w/Romraider, 600 at the motor is doable with that, I run 100% alcohol, the injectors are ported, I have them scaled to 800cc, they could take more, I'm sure of it, It doesnt bother me let people flack all they like, this is a for sale post on the internet, not a jury deliberation for a cereal rapist. I just find it comical about alot of people who get carried away with what they read on the internet haha..
    Jul 2004
    Seattle, WA
    Gotcha, so how much power is the car currently making?
    Does it have a clean title?
    Is the car currently licensed?
    And how about the stock parts in my edit?
    Aug 2008
    Ah yes, all the stock parts I have will be included with the sale, I pulled the shift knob off fore I just got done the trans swap and am picking up a different knob tommorrow. rear seats, belts, all brackets and bolts, rear wing. Vehicle does have a clean title and the car is currently licensed in the state of PA, it was previously licensed to the owner before me in the state of Virginia. The car is currently making close to 600 HP at 30 PSI. ( I understand your looking out for me with the post before, thanks bud haha )
    Aug 2008
    Bump Bump, price is somewhat flexible....
    Dec 2003
    Dallas, TX / Sterling, VA
    BUY IT BACK ROGAN!
    Registered User SlverEJ20's Avatar
    Dec 2007
    Midlothian, Fairfax
    ^^^ +1, I drove this car once and it was a ****ing blast. GLWS
    May 2007
    behind the wheel
    WTF??
    AJ, what's happening? I think I just got butterflies...
    I'll PM you my number..
    Rogan o_0
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties - 750 lb/ft
    Registered User ElVerde's Avatar
    Aug 2010
    Newport Beach, CA
    So...a dude that has sex with cheerios? Or does Capn Crunch have a dark side we didn't know about?
    I'm sorry, not trying to be a jerk but I found that to be too funny . Car looks great, GLWS
    ~ADAM
    70 El Camino SS clone
    2011 WRX Sedan in Satin White Cobb Stage 1+AEM Cold Air Intake
    Click here for my Progress Thread
    Installing HellaSupertones? Click here.
    N.E.R.D. #4
    Devout Practicalist
    May 2007
    behind the wheel
    Jeremy, it's my old car. It's legit.
    Rogan o_0
    Aug 2008
    excellant, my kind of humor haha
    Aug 2008
    bump
    Aug 2008
    Quote Originally Posted by ElVerde View Post
    Yeah i realized that after i posted...serial...
    Aug 2008
    bump
