For Sale/Trade NJ: 1996 Legacy GT w/2004 WRX swap $7500
Results 1 to 2 of 2
This is a discussion on NJ: 1996 Legacy GT w/2004 WRX swap 00 within the Vehicles for sale forums, part of the ClubWRX.net Marketplace category; I acquired this car over the summer. Although I really like this car, I'd like to see what I can ...
    Dec 2003
    central NJ
    I acquired this car over the summer. Although I really like this car, I'd like to see what I can get for it. I'm asking $7500 or trades of equivalent value (daily drivers ONLY, no project cars). The car is located in Central NJ. Here are the details:
    Year: 1996
    Make: Legacy GT
    Model: WRX Swapped
    Color: Green
    Mileage: 116,xxx
    Transmission: Automatic
    Description:
    Title: Clean
    Power windows
    Power steering
    Fully working cold A/C
    ABS
    Car is OBD2 compliant and runs off 02' WRX ECU, no CELs.
    Engine:
    2004 WRX swap only 17xxxk since build done by Pete(tehDIRT)
    ACL Rod bearings
    ACL Main bearings
    Gates Timing belt
    06' STi hollow cams
    TGV Delete and ported
    WRX TMIC
    3" TBE with spiral flow resonators under 1k miles
    Synic EL header and wrapped. under 1k miles
    SPT Intake
    HKS 3" Downpipe
    Transcooler
    02' WRX ECU Tuned by Ray
    Suspension: under 6k miles
    Cusco front lower subframe H bar
    Whiteline FSB Adj 22mm
    Whiteline RSB Adj 22mm
    Whiteline FBS Endlinks
    Whiteline RSB Endlinks
    04' Sti EMUSA 10kg 8kg Coilovers
    04' Sti Top hats
    GD STi Rear Upper Strut bar
    Ingalls camber kit F/R
    Interior
    02-03 WRX Front and Rear seats
    02-03 WRX 6 CD headunit
    GloShift Boost and Oil pressure gauges
    20% Tint by Shade of Gray tinting
    Replaced/Done:
    Front hubs and bearings
    Rear wheel bearings
    Front Axles
    Motul Synthetic oil
    Subaru Dealer transmission, front and rear fluids done
    NGK 7s Iridium by Ryan@1320
    Perrin turbo inlet hose
    Viper remote start
    The wheels are currently custom redrilled OEM BMW 16x8 ET23 Style 5's from a 1998 740iL, which can be included for $500, otherwise it will be running stock 15" alloys. The car runs excellent, boost is set at 10psi and is deceivingly quick. If u have any questions or offers, please feel free to PM or email.
    Thanks,
    Tony
    email: junfei@aol.com
    Dec 2003
    central NJ
    price drop $7000
