GSR (all-motor built) looking to trade for a wrx and some money or sell. Here's a little info in my GSR. Its really clean GSR inside and out. it has a all motor build that made 204 whp at Evans-tuning. the engine has 16300 miles on it with all its papers professionally built. In the engine and tranny alone it has 9K in reciepts with internals a machine work done. Here are some pics and what it has done to the engine.
Car:
2000 front and back bumper conversion
Black housing angel eyes
immaculent cloth interior (black)
painted S2K berlina black its a jet polished black
TYPE R wing (real deal)
Head:
port and polished
angle job
Type r valves
new OEM seals
new OEM head gasket
Skunk2 stage 3 cams
Crower daul valve springs
Skunk2 Titanium retainers
Skunk2 intake manifold
STI 72mm thorttle body
AEM red Cam Gears
AEM fuel rail
AEM fuel pressure regulator
AEM fuel Gauge
Precision 440 injectors
Weapon R secret weapon air inake
Block:
GSR over bored block .5
Balanced and honed Block (fresh)
Blue Printed
Crankshaft balanced
Crankshaft knife edged
eagle H-beam rods
CP high compression pistons (12.1:1)
OEM Bearings
all new seals and rings
OEM ype r bearings
ENDYNE breather kit
ARP head bolts
ARP rod bolts
Block gaurd
Moroso oil pan
Gates Racing performance timing belt
type r oil pump (new)
type r water punp (new)
braided fuel line
Tranny:
99 GSR fresh Rebuilt
Acid dipped (clean)
New Carbon coated gears and syncros
Quaife LSD
ACT stage 2 clutch
ACT pressure plate
8lb flywheel
Suspension & Wheels:
Omni Power Sport full Coilovers for Type R
Type R control arms
Enkie RS7 bronze rims 17 inches** NO CURB RASH**
Toyo proxes ZR tires
Crossed drilled and slotted Rotors
Hawk Brake pads
Other parts:
Neptune Programmed p28 Ecu - **Done by Evans-Tunings**
MSD Ignition setup
Edelbrock 255 fuel pump
Apexi WS2 catback
Rage replica TRI-Y header
Bigger Raidiator (better cooling)
2 new Denso O2 sensor
