FS Big Sky's very well sorted 04 wagon
Page 1 of 3 123 LastLast
Results 1 to 15 of 40
This is a discussion on FS Big Sky's very well sorted 04 wagon within the Vehicles for sale forums, part of the ClubWRX.net Marketplace category; The call for a 09 is becoming stronger and two cars isn't in the works, so I thought I'd give ...
    Jul 2001
    Plains of Eastern Montana
    The call for a 09 is becoming stronger and two cars isn't in the works, so I thought I'd give it a go here first instead of trading it in
    It's a 2004 WRX wagon, 5 speed, Aspen White w/ just shy of 64k on the odometer
    I've put a lot of tender loving care into these vehicle, every modification was purposely thought out. I tried to strike a balance between a daily driven grocery getter and weekend fun car. This is NOT a died in the wool track car, nor a dedicated autox car, but still no slouch at either A wonderful canyon/mtn. carver to be sure!
    Suspension- at the core of the suspension are Koni dampers in wagon housings, topped w/ STi Tarmac springs, RCE lowering camber plates up front and Group N tops in the rear. Ride height is a perfect 30mm drop f/r. Read my ongoing review of this setup here: Tarmac springs on wagon - NASIOC
    Sway bars are WL 27-29mm front w/ WL 22mm adj rear. Poltec spherical sway links at both ends. The lateral links are full aluminum, wagon specific w/ Grp N bushings pressed in w/ Poltec aluminum "boxes" for the sway links. Trailing links have Group N bushings front/rear. Group N bushings as well on the front control arms. STi titanium front strut bar, STI wagon specific rear strut bar w/ custom quick releases. Lower STi arm brace. WL steering rack bushings.
    I'll be selling the car w/ oe 17x7 2006 WRX wheels and oe RE92's (w/ like new tread). Wheels and tires are kind of a personal thing, so the new owner can figure out what's appropriate for his needs.
    Brakes- are FHI four pots w/ two piece DBA 5000 rotors, rears FHI two pots w/ DBA 4000 rotors, Ferodo DS2500 pads front and rear, Goodridge lines w/ Motul fluid. Calipers were recently rebuilt. Have several spare sets of pads- including DS3000's, spare rebuild kits f/r as well.
    Drivetrain-Grp N mounts including pitch stop, engine mounts, tranny mount and rear diff, STi short shifter, Prodrive rear diff cover
    Engine- pretty modest here: ScoobySport semi-divorced downpipe, STi uppipe, P&P exhaust manifolds Jet Hot coated, Prodrive muffler, Samco turbo inlet, Samco MAF, Samco intercooler hoses, Samco radiator hoses, STi panel filter (have a Prodrive intake that I haven't installed yet), EcuTek tuned
    the power is very usable and w/ the oe turbo/intercooler, it comes on very quickly
    Aero- I've fitted all the STi under aero bits- tranny cover, side cover and the rear diffuser (bolted on w/ the aid of the Cusco brace), STi aero guards
    Interior- I have two 45mm Omori gauges- boost and EGT in oe rubber housings, both w/ matching red needles and green back lit like the stock gauges- this is a very "oe looking" setup, Prodrive floor mats, Prodrive shift knob, Schroth quick fit harness that snaps in/out in less then 30 seconds
    the car exterior is in very good shape, as is the interior- this car is very (very) well maintained- my scheduled maintenance is very far ahead of Subaru's maintenance- probably not necessary, but it makes me feel better
    I've probably rambled on enough :lol:, I'm looking for $15,000 for this very well sorted WRX wagon.
    Moderator timber's Avatar
    St. George, Ut.
    oh dizzzam. Bump for an outstanding fellow.
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    dizzzam indeed.
    Your wagon for 15Gs? If this was almost exactly 1 year ago when I was searching for my wagon I would have scooped that in a heartbeat!
    GL with the sale.
    Jul 2001
    thanks gents won't be an easy car to let go- that is for certain
    May 2005
    Phillytown, PA
    ETA on "Project Hatch Begins"?
    Jul 2004
    Seattle, WA
    What kind of EM are you using?
    Jul 2001
    whoops- forgot that Ecutek tuned
    JR- we'll see- depending on how proud the dealer's are of the 09- this would be my third WRX from the same dealership so I'm assuming they will treat me good (but you know about the saying about assuming )
    Registered User 05Wrex's Avatar
    In the middle of a corn field somewhere in Illinois
    '09 for Bigsky
    Haha I knew it. The moment you started posting about the '09s I knew you needed one.
    OBP 2005 Wrx - Big 16g
    Jan 2003
    California coast/Sweden
    Finally I was ahead of BigSky, sold my wagon little over a month ago, thought I was gonna get a low mileage '06 with 2.5 l but it was sold just under me so I ended up with something else, something I've been wanting awhile but didt think I could afford. One of 2 cars I couldnt keep up with at Willow Springs, you know the saying..."if you cant beat them...
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    Your car is awesome. I wish I had the funds for another WRX wagon.
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Muwahahahhahah!!!
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Apr 2002
    Utah
    Quote Originally Posted by 06wrx4me View Post
    Muwahahahhahah!!!
    Does that mean you bought it?
    -- Steven Wright
    May 2005
    Phillytown, PA
    Quote Originally Posted by integra96 View Post
    does that mean you bought it?
    +1
    Jun 2006
    Nor Cal
    Quote Originally Posted by Integra96 View Post
    Nope, just felt like I helped push him into an 09 .
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    May 2005
    Phillytown, PA
    I think realistically, it was like talking a fat kid into another piece of cake.
