How to launch your Automatic - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 55
This is a discussion on How to launch your Automatic within the VDC, VTC, and 4EAT forums, part of the Transmission & AWD category; Originally Posted by Mario777 That sounds like the biggest load of crap. All you had was an exhaust? Was it ...
  1. #31
    Registered User c00lbeans's Avatar
    Portland, OR
    Quote Originally Posted by Mario777
    That sounds like the biggest load of crap. All you had was an exhaust? Was it a turbo-back catless exhaust or what? I have a turbo-back catless exhaust and a MBC set at 16 psi and my best launch is a 2.26 60' and 14.8@91 mph with 9psi of boost off the line. My car stock wouldnt hold a damn pound of boost when I brake launched it until I added the MBC. The downpipe made a night and day differance as well. I just installed my tranny cooler and hopefully I will have a catless up-pipe installed before the next track day but a 1.8 60' and 13.7 1/4 mile ET.....I wanna know what the hell else you have or what else you are doing because I need to do it for sure.
    I hold the ebrake and it boosts at 16 psi at 3100 rpm, got a 2.0xx 60' at 3400 elevation track. Ill try it at a better track this week
  3. #32
    Registered User ArizonaWRX's Avatar
    Aug 2006
    Lightbulb
    If you are at a light and want to take the car next to you, (or have to gun it to beat the car and merge quick )can you just put in in third and step on it, or can/does this hurt your transmission?
  4. #33
    Jan 2005
    Canada B.C.
    Yes, you can put it in 3rd... or 1st and shift it manually, it won't hurt the transmission.
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
  6. #34
    Registered User neversummersl28's Avatar
    Sep 2006
    NewJersey
    Quote Originally Posted by SLOW4EAT View Post
    or you can launch with line lock!!!!!!!!!!!!!!!!!
    anybody have more info on line lock?? how much it will cost and exactly how to use it with AWD?? im familiar with it in RWD drag cars to warm up the tires but i wanna know more for my WRX
    ~Robb~
    Hawk-Eye Alliance #828
    4EAT '06 SRR WRX Ltd.
    APS TBE
    SPT Intake
    Cobb Stage 2
  7. #35
    Feb 2007
    Buffalo, NY
    Quote Originally Posted by bmms8 View Post
    3rd goes up to 120?? damn, i trhought it went up to 90? i thought it was somewhere around 40, 72, ~90, havent actually floored it in 3rd to redline, so im only assuming.
    ive seen 135ish redlined in 3rd in my 4EAT!
  8. #36
    Feb 2007
    Buffalo, NY
    Quote Originally Posted by neversummersl28 View Post
    btw u can build your own line locks out of an old ABS unit. all they are is solenoids that need power and block off fluid flow.
  9. #37
    Sep 2007
    wondering if anyone else has the problem i do. when i sit in line a while at the track waiting for my turn or after the car has sat but is still warm. i go to brake boost and i cant build more than about 5psi. but if i drive for a while and come to a stop sign or something i can brake boost to 12psi. also if i do back to back runs at the track i can build 12psi. what could be doing this? no one seems to know.
  10. #38
    Jan 2005
    Canada B.C.
    I would think it's probly because of heat soak...
  11. #39
    Banned Subie do's Avatar
    Apr 2006
    Seattle WA.
    +1 for heat soak.
    Try driving around for a bit and let it cool off.
  12. #40
    Sep 2007
    Tranny
    How much would it cost for an auto Tranny replacement if I did too many brake starts?
  13. #41
    Registered User pumpkyn's Avatar
    Aug 2008
    WVC, UT
    alright, ive got an issue with this. only 3 times have i been able to launch at 3200 rpms out of probably 20-30 attempts. They all happened before i found this thread this past May.
    Now that I found this thread, I've tried this technique (and the 3 revs to 3k and a full rev to 6k) and it will always stay and hold at 2400-2500 rpm. I tried it again tonight with the 6k rev and it held at 2500 rpm, I held it there for 5-10 second in hopes it would finally rise. It didn't : I have felt a boost launch since April, when the car was still stock, I want to experience this with the stage 2. Is there anything else I could try?
  14. #42
    Registered User Subie do V2.0's Avatar
    Aug 2008
    Seattle WA.
    Quote Originally Posted by pumpkyn View Post
    Whats the temp like outside? Is the car warmed up?
  15. #43
    Registered User caffeineOasis's Avatar
    Jun 2004
    Illinois
    Since everyone is confused...
    first of all...especially being a turbo & also pretty much most cars,it runs smoothest at a cooler temperature.....[ps its summer]
    2nd....put 4EAT into neutral, hold break entire time, rev it up & continue holding the break & you'll feel the break decompress[go down further as you rev the engine], take foot off of gas & switch to Drive....
    ...rev up the engine(probably going to around 3000rpms roughly) and let go of break....
    I managed to pull this off at the track & yes it DOES work, but I also have an up pipe, down pipe, cat-back exhaust, and CobbTuning Engine Management....so this all together does help reduce turbo lag greatly.
    PS....DONT TRY THIS 30 TIMES/OFTEN
    look down......60', 1/8 mile, 1/4 mile w/ that^ w/ crappy tires
    1.98-------60'
    9.017-----1/8 mile
    14.16 @ 96 mph
  16. #44
    Aug 2008
    WVC, UT
    Quote Originally Posted by Subie do V2.0 View Post
    about 70* and its warmed up also right after driving it for 3 miles
  17. #45
    Sep 2008
    North Carolina
    tranny brake anyone?
    Hi fellas, I'm new to the forum but not new to wrx's
    Got a question: has anyone tried installing a trans-brake on their auto? If so I'd like to know how it worked out, and how much a kit would cost. Also, what kind of stress does a trans-brake put on the tranny?
