FAQ (look here first before posting)
Closed Thread
Results 1 to 1 of 1
This is a discussion on FAQ (look here first before posting) within the Tutorials & DIY forums, part of the Tech & Modifying & General Repairs category; PM me for suggestions, and I'll do my best to cater you Maintenance Service Manual excerpt: Periodic Maintenance Brake Pad ...
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    Maintenance
    Brake Pad Change
    Oil Change Discussions
    Bug Eyes Headlight bulbs and fog bulb replacement
    2004 Projector Fog Lights bulb change
    Spark Plug Change
    PCV valve change
    Subaru DOHC boxer timing belt replacement pdf
    2.5 RS oil change instructions with pictures
    Engine
    Blow Off Valve (BOV) Install
    Manual Boost Controller (MBC, Joe P) Install 1
    Manual Boost Controller (MBC, Joe P) Install 2
    MBC install #3 (2 threads combined into 1)
    Grounding Mod
    Uppipe, Downpipe, Muffler INSTALL GUIDE
    Fuel Injector Install tips
    Aquamist install (Water intercooler sprayer)
    DIY Intercooler Sprayer
    Turbo Timer Install
    Samco Intercooler Hose install
    ECU reset
    EGT sensor tapping instructions
    Homemade octane boosters
    Drivetrain
    Short Shifter
    RWD conversion
    DIY Hardened Transmission Mount
    Suspension
    Springs and Struts Install
    Strut/spring install with pictures
    Brake Pad Install
    Upgrade to the 04 Sway Bar mount
    Torque Specs/Socket Wrench size for Suspension/Powertrain
    Wagon to Sedan Suspension Conversion (Sedan trac on a wagon)
    Interior
    Boost Gauge Install
    Big Sky WRX's boost gauge install instructions
    Disabling AC with defogger
    Valentine One Hardwire
    Third brake light cover mod
    Dual Front Cupholder
    Radar Detector Hardwire 2
    Cabin Air Filter (Right-Click/Save As)
    Subaru Single Boost gauge Install (Right-Click/Save As)
    Removing the film on the gauge cluster to change the lighting color
    Subaru keyless entry programming instructions
    Exterior
    McCulloch HID kit Install
    Side Marker Lens Install
    Fog Light with High Beams
    Morrette H7 HID install
    WRC Headlight Knockoff install
    Wagon roof-rail removal
    Koji style Blacked out headlights and orange turn signal cover removal
    WRXfanatics posting on Koji Style
    Orange Turn Signal Cover removal without removing the headlight lens
    2002-2003 Fog Install (Right-Click/Save As)
    2004 Fog Install (Rick-Click/Save As)
    Fog Lamp Brake Ducts
    DIY PnP harness for JDM/EDM bugeye headlamps
    Subaru paint codes
    Subaru Performance Tuning install instructions
    Quick reply to this message Reply
Closed Thread
