Success! on retained window power for 2015-
Results 1 to 5 of 5
This is a discussion on Success! on retained window power for 2015- within the Tutorials & DIY forums, part of the Tech & Modifying & General Repairs category; I just completed wiring up my 2015 for retained window power where I can stop, turn the car off and ...
    Registered User rqjoe's Avatar
    Feb 2015
    Ohio
    I just completed wiring up my 2015 for retained window power where I can stop, turn the car off and have time to put up or down the windows before the relay cuts power to them. In the broader car world this called Retained Accessory Power (RAP.) I used one Beuler time-delay relay and one diode. I cut the green wire between the ign switch and the power window relay. The following is a list of connections:
    86 (coil voltage in) -- to cut green wire going back to ign switch -- diode is inline here between coil in and switch wire
    85 (coil out) -- ground
    87 (relay contact out) -- to cut green wire going to power window relay
    30 (relay contact in) -- always hot contact inside MB (fuse box under hood)
    With the Beuler time-delay relay I can set the time for how long I want to maintain power. I set mine at 35-40 seconds. It works. I have seen other posts about this but none that say they actually implemented it and got it to work. Mine is done and working. I will add a diagram later when I get a chance in case anyone else wants to do this. But be warned it took a while and you have to be persistent to get it done right. I did it over a couple weeks working a little bit each night and a couple Saturdays a little. Actually hooking up the wires is not hard; it is finding the right wires in the car, finding a ground point, actually running a whole new hot wire from under the hood to near the cabin fuse box in my case (quite a chore and this is where I had most of the front fender off but found I only needed to remove the plastic wheel well liner later,) that takes time. So while I will post a diagram, I will not go into the specifics of where I connected everything on the car unless someone really honestly plans to do this. And if you do, you may have to message me as I may not look back at this post; getting forgetful.
    Life is good now..........
    "Hey man there's only one thing
    And one car that will do"
    And its a WRX Subaru
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    Cool, glad you figured it out.... but I think I'm ok with just using the window switch before I turn the car off.
    The Anti-N00b. Use "Search", YES, you need a tune. NO, you don't need a BOV. Don't try to make you car shoot fire, and change your freaking oil.
    Feb 2015
    Ohio
    diagram
    Connections
  5. #4
    Jun 2009
    subbed good info!
  6. #5
    Feb 2015
    Ohio
    pics
    Not sure these will help too much but......
