Engine removal
Results 1 to 4 of 4
This is a discussion on Engine removal within the Tutorials & DIY forums, part of the Tech & Modifying & General Repairs category; Hi guys just a quick question... I have spun bearing in my 2011 WRX... and am currently yanking the engine... ...
    Dec 2012
    Colorado Springs, Colorado
    Engine removal
    Hi guys just a quick question... I have spun bearing in my 2011 WRX... and am currently yanking the engine... all is well except for the Damn Down pipe where it mounts to the turbo... all of the bolts are seized... I've tried everything that's at my disposal short of cutting the bolts out with a dremel or something simular... so far I've tried 1/2 dr impact no room to get it in there... 3/8 drive impact didn't have enough balls, and 1/2 and 3/8 dr air ratchet both didn't have enough balls... a regular socket with a breaker bar is round off my bolts... I dont know what else to do...
    Jan 2012
    New Jersey
    PB blaster, you can freeze it or you can get a torch
    2012 WRB 4DR | SPT Exhaust | Cobb Short Throw | Rally Armour | WC Lathe Werks Custom TI Knob | Kartboy Bushings | Stoptech Pads & Brake Lines | JBK Elements DRL | STI HID Retrofit | XB LED Angel Eyes | GrimmSpeed Lightweight Crank Pulley | Perrin Cold Air Intake
    CFLip2x 2012 WRB WRX Build
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Quote Originally Posted by cflip2x View Post
    This, I let mine soak in an extensive amount of PB blaster for a good hour then still couldn't break them loose without a 24 inch breaker bar and a lot of force from yours truly.
    2011 WRB WRX Sedan - Q300, Invidia Catted Downpipe, Cobb RAM Intake w/Box, Tuned by Turn in Concepts
    Stink-Eye Mob #696
    Build Thread
    Facebook
    @billym14
  5. #4
    Dec 2012
    Got em out... one of them with a jigsaw and a cutting wheel... and the other with penetrating oil and a 14mm pump wrench with a lot of force behind it... thanks for help guys...
