DIY Remove Hill Assist WRX 08-13
Results 1 to 15 of 26
This is a discussion on DIY Remove Hill Assist WRX 08-13 within the Tutorials & DIY forums, part of the Tech & Modifying & General Repairs category; This will be a tutorial for 2008-12013 subaru wrx. This will remove the hill assist and turn off the day ...
    Feb 2013
    Pittsburgh, PA
    This will be a tutorial for 2008-12013 subaru wrx. This will remove the hill assist and turn off the day time running headlight.
    1. remove handbrake boot
    2. unbolt the screw on the top left corner
    3. unbolt the two screws in the arm rest
    4. lift up the top part of the console
    5. undo the bolt in the red arrow
    6. just twist the spring with green arrow so that it does hit the brake lever
    7. tighten the bolt and put everything together.
    Every i get enough ppl to ask me to make a video i will.Click image for larger version.
    Dec 2012
    South Jersey
    You'd think you'd want this in Pittsburgh! I've grown to like it now that I know it's there. When it caught me off guard it was annoying.
    edit: thankful for you writing it up though
    Registered User chutoyy's Avatar
    Sep 2012
    Seattle-ish, WA
    Haven't taken a look at it myself... Is there a separate switch for the 'brake' warning light? or is that constantly illuminated?
    2013 WRX Plasma Blue Pearl
    Registered User Hoofhearted's Avatar
    Aug 2011
    Nice, ill probably make a video of this for the people that can't follow instructions.
    Sent from iPhone
    2011 Base WRX
    Feb 2013
    Pittsburgh, PA
    Quote Originally Posted by rquinn19 View Post
    Once you know how to drive a stick it really doesn't matter where your driving. The hills assist throws me off and i stall lol
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Quote Originally Posted by chutoyy View Post
    The brake warning light on the dash will be constantly illuminated, unfortunately.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    That's what I thought, and that makes for useless, sorry - not my thing.
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    in these newer cars, does that parking brake switch also turn off the low-beam headlight?
    David - '05 WRX
    Mar 2012
    I have the HID low beams. During "normal" daylight driving the DRL's are the hi-beams on low power. The hand brake turns them off, like when sitting on a hill at a traffic light. Once the LIGHTS are turned on, like driving early in the morning, the DRL's are off and handbrake makes no difference on the lights. When pulling the turn signal switch for flashing the hi's, the drl's go full power, no matter if DRL or low beam lights are on.
    The better solution for getting rid of DRL is to pull the relais behing (or really in front of) the glove box. . .
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Pull the cluster and see if you can remove the bulb for the brake light. It would be pretty easy on my 02 not sure about other years though. As long as you remember when the hand brake is on you should be good.
    Mar 2012
    Not so on the 08+. They have SMD LED's soldered to the circuit board and it's not that easy. I personally am not inclined to take that apart. And even then you'd be limited to put a cover over the LED, since removal of LED is either not possible or would destroy the assembly. There is a write-up for the TPMS light that goes there, the light gets covered. But in that case the circuit board is pulled away from the instruments as in "gap" and cover slid in between. Any more separation and the instruments are shot. I'm not ready to replace the cluster...
    Registered User Sheleileigh Law's Avatar
    Nov 2012
    You can 'undo' the hill assist without monkeying around with the car like this - you're at a hill, you stop, as usual. Let your foot off the brake pedal and after a few seconds, the hill assist stops AND when you put your foot back on the brake again - it doesn't come back - for that stop only, of course.
    Sort of a work-around ...
    Feb 2013
    Pittsburgh, PA
    Quote Originally Posted by Sheleileigh Law View Post
    Why would you do that? Who would want to do that on every single hill?
    Feb 2013
    Pittsburgh, PA
    duplicated.
    Nov 2012
    Quote Originally Posted by huey412 View Post
    I don't, but it's something I discovered by accident that disengages the hill assist, so thought I'd let folks know, as some people really hate the hill assist function and maybe don't want to monkey around with the car.
