02 WRX Manual boost controller
Results 1 to 10 of 10
This is a discussion on 02 WRX Manual boost controller within the Tutorials & DIY forums, part of the Tech & Modifying & General Repairs category; Hi, my 02 wrx was a lemon and im slowly getting it back up to par. But the Turbo set ...
    Registered User Jerembo47's Avatar
    Nov 2009
    San Diego, CA
    Hi, my 02 wrx was a lemon and im slowly getting it back up to par. But the Turbo set up is kinda wack!
    There is no boost controller at all! 1 Line (the blue one) that goes from the wastegate to the turbo. So I bought a cheap ebay MBC
    I just need a little bit of help and advise on installing this without blowing up my engine. I found this
    http://ezinearticles.com/?How-to-Ins...gine&id=361277
    and this
    CobbTuning.com - How Subaru’s Factory Boost Control System Works
    But I have questions about the restrictor pill. If i even need it because with the current set up I don't think there is a restrictor pill. Pls help any feed back will be appreciated! Thanks!!!
    Feb 2010
    SL,UT
    Why not just get engine management if you want more boost? It will be a lot safer for your engine, plus you wont have to worry about running lean...
    Hawk-Eye Alliance #801
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by 06scoobyrex View Post
    With no boost controler he's going to be running waste gate pressure, EM or not.
    OP, your best bet is to find a STOCK EBC for your car and install that. A step beyond that would be installing an aftermarket 3-port EBC and having it professionally tuned.
    In any case, if you're dead set on running a MBC, you need to have your car professionally tuned for it. In other words, you're not going to be able to safely install that cheap eBay MBC without shelling out at least $300 for a tune.
    (running straight waste gate pressure isn't really going to hurt your car, but it's certainly not going to perform its best)
    Feb 2010
    SL,UT
    True... his post had me kinda confused on what he is trying to do, some kind of Jerryrigging his car back together...
    OP- Was this done by the previous owner or are you just trying to work your away around power without tuning?
    Jan 2005
    Canada B.C.
    You can just hook it up like the COBB picture shows except with the MBC in place of the factory boost control solenoid, you can probably get away without the restrictor pill with a MBC... Don't set it any higher than 16.5 Psi and watch out for FBPT...
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Nov 2009
    San Diego, CA
    The current set up is the way I bought it. I'm just kinda short on $ at the moment and trying cheap alternatives to get more performance out of my subie! Its rediculouse getting beat by a stock civic! The way its set up now I'm only getting 7-8 psi.
    Jan 2005
    Canada B.C.
    Yes, I understand, wastegate pressure is all you are getting. The easy/cheap quick fix is a MBC but there is a downside of FBPT so be careful read up on that...
    Jun 2011
    A manual Boost controller is a recipe for disaster
    Registered User batorr's Avatar
    May 2011
    Rochester, New Hampshire, United States
    i ended up going this route on my car with a 3 port ebc. it runs about $110 but it's easy to install. this video gives you a play by play but you will need a pill and a tune.
    YouTube - ‪GrimmSpeed Boost Control Solenoid Install‬‏
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Running straight off the wastegate is fine... i do that with my external wastegate. You dont need the computer to control the boost or even a boost controller.
