Results 1 to 4 of 4
This is a discussion on MBC Install instructions or guide. within the Tutorials & DIY forums, part of the Tech & Modifying & General Repairs category; I have looked through a couple of the posts I have found through search but nothing to detailed or with ...
    Registered User AsILayDying's Avatar
    Dec 2008
    Central Florida
    I have looked through a couple of the posts I have found through search but nothing to detailed or with photos of how to install a MBC in a WRX/STi. If someone could just point in the right direction it would be appreciated, I know this should be a simple install but I am still relatively new to Turbo vehicles, and all the terms or names of lines of hoses and such are a little tough to figure out just by words. A good photo does wonders. Again thanks for the help.
    The reason for MBC install is because I am overboosting with COBB AP Stage II and they recommend a MBC and turn down boost a little until I can afford a ProTune map. Im tuned for 16.7 and Im peaking 19.5psi. Thanks again for any help.
    BlobEye Syndicate #-666
    Stage II 04' WRX Black (Performance Race Solutions Tuned 310whp)
    "its never enough"
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Good link.
    As I lay dying...
    Remove the T to the BCS... remove the restrictor pill inside the vacuum hose coming from the compressor, but leave the line... and put the MBC in where the T was originally at.
    It's cake. You can re-route vac lines, do some mounting, etc... but that's the principle.
    Moderator Donkey's Avatar
    Da boonies
    Also you better have a tune to go with it especially with an 04-05 wrx.
    2002 FORESTER S
    1998 FORESTER S
