CEL fix no good on 04's - Page 5
Page 5 of 8 FirstFirst 12345678 LastLast
Results 61 to 75 of 114
This is a discussion on CEL fix no good on 04's within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So i guess the resistor trick does NOT work for the 2004's...****ing POS.......
  1. #61
    Sep 2003
    Alberta, Canada
    2004 Rally Blue WRX Sedan
  3. #62
    Registered User the mike's Avatar
    Dec 2002
    Delran, NJ.
    I don't know where the problem is...I wired a 1M ohm resistor in and have no CEL. Still tuning the UTEC though, might have something to do with it.
    Creeping up on creeping for a decade.
    Bugeye Mafia V2 #322
  4. #63
    Sep 2003
    Alberta, Canada
    the mike- did you reset your ECU after you installed the resistor?? or did it go off by itself after awhile?
  6. #64
    Dec 2002
    Delran, NJ.
    Never reset it, I did the resistor mod with the uppipe off the car, so they went on at the same time. Hasn't come on yet, but if it does I'll let you know.
    mike
  7. #65
    Sep 2003
    Alberta, Canada
    im not getting the EGT CEL, im getting one from the down pipe
  8. #66
    Dec 2002
    Delran, NJ.
    I'm an idiot, I meant DOWNpipe. It was late when I posted.
    I still have the stock uppipe.
  9. #67
    PEP
    PEP is offline
    Oct 2003
    Overland Park, KS
    Dan Smith
    Pony Express Performance
  10. #68
    Sep 2003
    Alberta, Canada
    Ok after you put this one in does it come off right away or what??
  11. #69
    Jan 2003
    Mereniuk,
    maybe you should try resetting the ecu then?
    I got my cel with 80km of losing my DP cat. Put the resistor in, pulled the neg terminal on the battery and haven't had a cel in 2000 km.
    the resistor works, and it only cost me 75 cents.
  12. #70
    Sep 2003
    Alberta, Canada
    yah i reset the ecu and i havent had one yet, and its been about 100kms!
  13. #71
    Registered User WRXncrew's Avatar
    Jul 2003
    San Jose, CA
    Question
    Anyone here using the non-electronic (no soldering) CEL fix on their '04? If you've not tried it, I recommend you do because it is very easy to install and it definitely works on the '02 and '03.
  14. #72
    Sep 2003
    Alberta, Canada
    huh??
    whats thats!??
    p.s- its been 230km's...no CEL!
  15. #73
    Registered User XtmX's Avatar
    Jun 2003
    Pittsburgh
    Cool
    1000 miles logged, still no CEL!!!!
    04 JBP
    Stock - they are watching.
  16. #74
    Sep 2003
    Alberta, Canada
    460km's!!
  17. #75
    Registered User 04EJ25's Avatar
    Sep 2003
    Old Bridge, NJ
    Question
    I just went to COBB's Stage 2 with a Perrin DP (and Perrin UP). No CEL yet, and I'm using the resistor fix. How long does it take for the CEL to come on for those of you w/ this problem???
    I just bought a STi!!!
    Love it!!!
