Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 48
This is a discussion on Cobb AP: Where are the Maps & What is my target Psi!? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Originally Posted by durbiwrx idk if this is the right spot to ask this question but, is it possible to ...
  1. #31
    Quote Originally Posted by durbiwrx
    idk if this is the right spot to ask this question but, is it possible to use a stage II map on an AP with the stock downpipe instead of a high flow one to acheive higher boost levels?
    The map notes explain the modifications required to run each map. If your car doesn't meet those qualifications, then do not flash that map onto your car.
  2. #32
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by durbiwrx View Post
    Do NOT do this. In order to create more boost you have to be able to flow a certain amount of exhaust gas through the piping. The stock down pipe can not handle this flow due to the catalytic converter in it and you will be putting the turbo under a lot of stress to attempt to achieve these higher boost targets thanks to too much back pressure. I repeat, do NOT do this.
    Some people have gutted their stock cat's and had success with a stage 2 map, you can try this, but do not leave the cat intact and go to a stage 2 map.
    Cody
  3. #33
    Registered User durbiwrx's Avatar
    Mar 2009
    bethlehem, pa
    thanks dude, glad i didnt decide to try that ha. sounds like bad news.
  4. #34
    Registered User Boxing Fan's Avatar
    May 2010
    Whats "PILL"??????????
  5. #35
    Moderator Donkey's Avatar
    Da boonies
    Quote Originally Posted by Boxing Fan View Post
    http://www.cobbtuning.com/info/?ID=3482
    2002 FORESTER S
    1998 FORESTER S
  6. #36
    Jun 2010
    Camp Pendleton, Portland OR
    so i have hear that you can share maps and there is a place for people to do this but all i can find is the cobb maps.
    is there somewhere i can get a map for:
    intake, FMIC, 4" downpipe and 4" exhaust
    or even one for e85?
  7. #37
    Da boonies
    The Cobb map sharing thing really never got off the ground. The only thing you can do is get a custom tune from a licensed Protuner.
    2002 FORESTER S
    1998 FORESTER S
  8. #38
    Registered User Tinyhands's Avatar
    Aug 2011
    Atascadero California
    i was wondering when you buy the cobb AP can you get the stage two map with out buying their down pipe and cat-back?
  9. #39
    Da boonies
    All of their maps are free and downloadable from their website.
    2002 FORESTER S
    1998 FORESTER S
  10. #40
    Jul 2010
    Cincinnati
    In fact if you buy it from someone other than COBB, many times it will come with additional maps beyond COBBs. Since vendors can't discount the price sometimes they add maps to make to more appealing to consumers. Maybe something to consider
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
  11. #41
    Aug 2011
    Ok perfect! Thanks
  12. #42
    Registered User silver sti's Avatar
    Jun 2011
    Rockland, New York, United States
    Hey , you may have mentioned info I am about to ask but I haven't read thru it, I just got a cobb access port listed 02-05 or so wrx 2.0, I have a 04 sti ,question is can I still use this tuner and or get maps for my sti ? or am I screwed ; ) thank you ahead of time
  13. #43
  14. #44
    Jun 2011
    thank you , That sucks ; )
  15. #45
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    your car has the 32bit ECU... the 02-05wrx have a 16bit ECU. Sorry bud!
LinkBacks (?)
  1. FAQ
    Refback This thread
    04-16-2008, 09:04 PM
