2016 sti pushing low boost
Results 1 to 10 of 10
This is a discussion on 2016 sti pushing low boost within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So I purchased a new 2016 sti last month and put 1300 miles on it all while properly carrying out ...
    Feb 2016
    So I purchased a new 2016 sti last month and put 1300 miles on it all while properly carrying out the break-in procedures. Then started noticing oil spots under the car, lifted it up and sure enough it was already leaking oil from the turbo area. Took it back to the dealer and they replaced the whole turbo assembly under warrenty as the car is stock aside from axleback tips. Problem is, I'm now only hitting 11 psi max boost in all 3 modes. Any suggestions before I take it back to the dealer?
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    Did you give the new turbo time to break in?
    I have an STi with an intake and no tune, I never change my oil, and my wheel spacerz are mad tyte.
    Feb 2016
    The techs said that wasn't necessary. But to break the turbo in, would that mean another 1500 miles of easy driving?
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Zkenny10 View Post
    No.. first thing that needs to be done with a new turbo is to prime it so that there is oil in the cartridge before the engine is started. To do this you simply pull the fuse to the fuel pump (or ignition) and crank the engine for about ten seconds. This must be done BEFORE the engine is started with the new turbo installed. As soon as the engine fires up it starts spinning the turbine and will cause damage to the turbo if it hasn't already been primed. I would prime the turbo three or four times before starting the engine, then let it sit and idle for 20-30 minutes.. after that, try not to go WOT for a couple hundred miles. After 200 or so miles it should be good to go.
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    Definitely take it back to the dealership ASAP.
    Feb 2016
    Update for you guys: took it back to the dealer expecting it to need a new turbo or related component, turns out they simply forgot to reconnect the vacuum tubing. Took only a few minutes to correct.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    WTH? That is unacceptable.
    It could have been much worse, and that's the problem. Negligence.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Aug 2008
    **** happens. I'm glad it worked out.
            MainFrame's Avatar
    Austin, TX
    For real.. forgetting to connect the vacuum lines? That could have been a blown engine 100 yards from their parking lot.
    Registered User mustwarnorcas's Avatar
    Sep 2015
    HB, CA
    Yeah that's a pretty major thing to leave disconnected, try and guilt them into some free routine maintenance unless of course you're afraid they might not put the drain plug back in after an oil change lol
    "If the power increases, then I have to spend more money on gas" - Takumi Fujiwara
    Build: http://www.clubwrx.net/forums/builds...eye-wagon.html
