Hello Everyone!
I rarely try to go WOT when daily driving, but it has been known to happen when called for. I noticed that tell-tale signs of Knock (Sounded like marbles in the engine) when I was at WOT. I had only previously used RomRaider/ECU Flash to pass emissions due to my exhaust and knew I would need a tune at some point, but the sound of knocking made me realize this needs to happens sooner rather than later.
I have been reading all weekend about logging and how to read them, but wanted some advice on how to proceed. I will be doing a 3rd gear pull tomorrow (either on my way to or from work) so I can dissect it further, but decided it may be a good idea to use Learning View and figure out what my FLKC was. As seen in the screenshot, it reaches -5.27 in one of the cells...Is there anything I should do before making my log tomorrow? I really don't want to be WOT as much as possible, and I don't notice any knock when I'm only half throttle regardless of RPM. Help?
2003 WRX - Pretty much stock except for the below mods
Catless Up-pipe
3 inch APS TBE
Mishimoto TMI
Catless Up-pipe
3 inch APS TBE
Mishimoto TMI
