Which map??
Results 1 to 11 of 11
This is a discussion on Which map?? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Just got a cobb ap for my 2007 2.5 wrx wagon. I also just put in an invidia v3 catless ...
    Nov 2014
    Medford Oregon
    Which map??
    Just got a cobb ap for my 2007 2.5 wrx wagon. I also just put in an invidia v3 catless dp and the invidia n1 race catback with no cats as well. I noticed the ap comes with a lot of stock maps, I'm assuming I need to install a stage 2 map but which one?
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    If you read the map notes of each one, it will tell you exactly which mods are supported for that map. No more, no less. Otherwise, your other determining factor is what fuel you use. There are 91 oct maps and 93 oct maps. Use 93 unless you live in an area where only 91 is available.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    Nov 2014
    Medford Oregon
    Thanks, I found some of the map notes online
    Nov 2014
    Medford Oregon
    So, I guess this is the "tune" everyone said my car would need after I put my exhaust on??
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by J_saucy View Post
    Yup.
    I didn't know they made Off-The-Shelf (OTS) tunes for catless downpipes, however.
    2011 STi Build Log
    Nov 2014
    Medford Oregon
    Yup.
    I'm not sure if they do.. Do I need to find another map for that? In the notes it just said the requirement was an "upgraded turboback"
    May 2010
    Pittsburgh, PA
    Read the first question/answer here: COBB Tuning - 2007 Subaru Impreza WRX MT Stage 2 Map
    ...Better than nothing, that's for sure. You may want to consider a professional tune if you are stuck on going catless.
    I would take some time and do some reading to learn how to log knock parameters and your fuel trims. It's not too difficult with the access port, and would help give you some piece of mind that everything is doing what it should.
    2011 STi Build Log
    Palmyra, NJ
    On the 2007s, you should be ok, but you *could* risk boost creep. The map notes state "Catted downpipes" but I've always thought that was Cobb just covering their asses so that they aren't a large company condoning putting non-road legal parts on cars for the road. I specifically recall back on my 2007 STI 8 years ago, that the map notes didn't mention anything about catted or catless either way and that it was a moot issue.
    That being said, I'm not guaranteeing that you'd be fine, but you should run logs just to keep an eye on things and ultimately get a protune to ensure that your car runs at tip top.
    May 2010
    Pittsburgh, PA
    I personally would be pretty concerned. If it's enough of a difference to cause boost creep (or not), it should be reflected in the boost control tables.
    I forget if the 07s were 2.0s or 2.5s to be honest. For what its worth, on my 2011 2.5, I had such bad boost creep issues after going catless that I ended up getting an EWG. I was hitting 18psi at redline in the cold with no wastegate duty cycle. If I had been using an off the shelf map that had a minimum wastegate duty cycle in it, I could have easily been above 20psi at redline.
    Seems like its a bit late for the OP, anyhow, as he already has the catless dp installed. If he goes in for a pro tune and the tuner finds him hitting boost creep, I doubt a good tuner would let him go without an EWG or getting the wastegate ported. Going catless on the 2.5s is a slippery slope, sadly. If its a 2.0L, I don't have any experience with them.
    2011 STi Build Log
    zax
    zax is online now
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    the TD04-13T in the WRX has a significantly larger wastegate port than the VF39/43/48/52 despite being smaller overall. Catless is fine with these cars.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    May 2010
    Pittsburgh, PA
    Yay Subaru!
    Still, i'd expect the boost control tables to change a decent amount using a catless downpipe on a tune designed for a catted one. I doubt it would be anything dangerous (I'd hope Cobb would open the WGDC correction range up a lot), but it wouldn't be ideal by any means.
    2011 STi Build Log
