vacuum discrepency
Results 1 to 6 of 6
This is a discussion on vacuum discrepency within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; finally got around to installing my smy gauge cluster (thanks irickchad, still tryna leave you feedback but the system is ...
    voidin warranty since 05 unseen's Avatar
    Jan 2015
    631 to 516
    vacuum discrepency
    finally got around to installing my smy gauge cluster (thanks irickchad, still tryna leave you feedback but the system is down). with autometer pro comp mechanical boost gauge and aem wideband o2.
    it seems that my boost gauge reads about 22 in vacuum while the ap reads around 10.2 (both readings at idle). boost is the same reading. whats the deal with this, and is it something i should be worried about?
    edit: i also notice that boost gauge sits at 2 in vacuum when off, so its an even 20 when in idle. still, 20 vs ap's 10 is a big difference.
    thanks.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Gauge is in inhg and AP is in PSI.
    22inhg = 10.8psi
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jan 2015
    631 to 516
    22inhg = 10.8psi
    as in mercury pressure? like for barometric pressure? humm thats interesting. zax to the rescue. thanks dude.
    so how come boost pressure is equal in both inhg and psi in gauge and ap, respectively.
    zax
    zax is offline
    Nov 2008
    Because the AP is correct and not following some ignorant muscle car trend set 4 decades ago.
    Facebook me here
    Jan 2015
    631 to 516
    haha okay. thanks again for the input. i guess what i was asking was, even if both are measured in different units, wouldnt they be proportionate on each side of vacuum and boost.
    so if the gauge is 22 inhg and the ap is 10.2 psi, would that parallel be on the boost side as well. just throwing out numbers, 24 inhg boost on gauge and 14psi in ap.
    Jan 2015
    631 to 516
    I see it now. Vacuum is measured in inhg and boost is measured in psi. I get it.
