My boost target tables are calling for 15psi in the mid range rpms over about 80% throttle (standard AP stage 1 91 oct map)
The problem is my logs show that my Target Boost is maxing out at 12.45psi even when it should be targeting 14 or 15 psi. What could be causing this? Also note that I am NOT saying that I cant reach target boost, rather the target boost itself is maxing at 12.45.
(Does it have something to do with a slight overboost correction? Although, I wouldnt think so, since it wouldnt be overboosting if it was targeting the correct boost.)
All advice appreciated.
https://drive.google.com/file/d/0B--PGLSfv5RmTkYtTWN6YXU1UDg/edit?usp=sharing
2002 wrx - mods: Invidia UP, TXS CBE, intake silencer delete.
