ECU bricked?
Results 1 to 3 of 3
This is a discussion on ECU bricked? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So I need a little help or advice. 2013 WRX. I just tried to flash my ECU with the fourth ...
    Registered User Dutch13SE's Avatar
    Jul 2014
    Las Vegas
    ECU bricked?
    So I need a little help or advice. 2013 WRX. I just tried to flash my ECU with the fourth stage 1 revision from Torqued Performance with ECUflash and Openport 2.0 and it gave me an error while reflashing. I did three successful flashes and a lot of logs with Romraider for the past couple weeks. Now the car won't start, all electronics come on but won't turn over at all. Can't flash any maps or even read the ECU. Talked to Eric from TP and he said its most likely a bricked ECU. He said to call either Tactrix or Cobb to send my ECU to try and get fixed. Anybody have any other suggestions or remedies? Thanks.
    Moderator Donkey's Avatar
    Da boonies,Va
    Try removing the negative battery cable and then hold down the brake pedal for about a minute. Re-install neg battery cable and see if you can now flash. If not you will have to send it to the places mentioned above unless you are somewhat computer savvy.
    How to Unbrick an ECU. Like A Boss! - NASIOC
    2002 FORESTER S
    1998 FORESTER S
    Jul 2014
    Las Vegas
    Yeah I already tried that, no luck. I guess I'll be sending it in. I emailed both companies but I'm not gonna hear back from them until Tuesday. Any idea on how much each company charges for this?
