2013 STI datalog
Results 1 to 15 of 17
This is a discussion on 2013 STI datalog within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; datalog S#.pdf datalog I.pdf 2013 STI MODS: Invidia catless DP, Invidia dual N1, Cobb Accessport V3 Stage 2 OTS map ...
    Registered User atranz's Avatar
    Aug 2012
    houston, tx
    2013 STI datalog
    datalog S#.pdfdatalog I.pdf
    2013 STI
    I did 2 datalogs (forgot to put it in sport sharp on one) datalog I and datalog S#. Let me know what you guys think? Hopefully i can take my car to AWDtuning in the next year.
    thanks for the help,
    ATran
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Your boost in the datalog I looks all sorts of wacky to me. According to the log it looks like you are overboosting by more than 2psi at WOT. I'm not sure exactly how the Cobb AP works the the Si drive in the STI's but it doesn't look right. I think the ROM only loads to one of the two settings and you have to leave it there. Someone else can chime in on that.
    Now in your S# log, what is your target boost with the OTS map? From what I can tell it looks to be at 18.8psi It doesn't look as if you are over boosting though on that setting, which is good. The S# log certainly looks a lot better that the I log.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    Aug 2012
    houston, tx
    Quote Originally Posted by McBill View Post
    I'm not 100% sure about the cobb's boost targets, but i want to say cobbs OTS is set at 18. It might be wise to keep it in s#? I'll try and do another data log in s#.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by atranz View Post
    https://cobb.app.box.com/SUBA-US-STI-08-14
    18.5 PSI
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Sep 2013
    Buckeye State
    Now, here is my question Zax. Does the AP only flash one of the two modes in an STI? because the one data log looks like a stock MAP... and if so then he should never run that mode with his mods.
    Billy
    Stink-Eye Mob #696
    Facebook
    zax
    zax is offline
    Nov 2008
    Do you mean boost select? No. This is the benefit of requested torque: you can tune the different throttle modes to target boost differently.
    Facebook me here
    zax
    zax is offline
    Nov 2008
    FYR OP: You have too many parameters logged. What is the purpose of your datalog? If you are logging for a specific purpose, you should be logging only the necessary parameters to ensure the best temporal resolution.
    Facebook me here
    Sep 2013
    Buckeye State
    Got ya, this makes sense now. So then what's the deal with his I log? looks like some overboosting to me. Starting to learn how to read these more in depth. /threadjack
    Billy
    Stink-Eye Mob #696
    Facebook
    Aug 2012
    houston, tx
    No biggie im learing myself.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    zax
    zax is offline
    Nov 2008
    No, not at all:
    The datalog shows peak boost within acceptable range for the map. OP's peak boost is at 18.8 PSI (from the resolution logged) while the map's target boost is 18.5 +/- 1.0 PSI
    Boost threshold of ~3000 PSI is normal for a VF48 STi. It would be nice to see a datalog to redline.
    Facebook me here
    Aug 2012
    houston, tx
    Zax, what is your recommendation on which parameters I should log? What I have was set from factory.
    zax
    zax is offline
    Nov 2008
    What is the purpose of your log? The parameters and methodology should be based on an a priori understanding of what you're attempting to see
    For example, if I'm tuning timing I will Datalog different params from if I'm tuning fueling.
    Facebook me here
    Aug 2012
    houston, tx
    The purpose of my log is to make sure everthing is runing safely and im not over boosting.
    zax
    zax is offline
    Nov 2008
    In which case you should log boost, target boost, calculated load, throttle, and rpm
    Facebook me here
    Aug 2012
    houston, tx
    Ill change my parameters and perform another datalog. I have a feeling im over boosting we'll see. Thanks for the help. Ill try and post the new datalog soon.
