Ecu failure
Results 1 to 14 of 14
This is a discussion on Ecu failure within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Ok guy a I have a 2014 wrx stage 2 with exaust and turbo inlet and intake Mansfield hose access ...
    Registered User Tommyjtr's Avatar
    Apr 2014
    Wichitafalls tx
    Ecu failure
    Ok guy a I have a 2014 wrx stage 2 with exaust and turbo inlet and intake Mansfield hose access port Tuner from Cobb . The other day my car just shut off and won't start the dealer says my ecu is toast and that my tuner is to blame. Fist has anyone ever heard of this happening to anyone els and what did they do?second is their after market ecus out their for tuned cars ( stronger ecus ) if so who makes them and what's the cost . I need some advise as now I'm scared that I'll be out. Grand for a stock ecu and it's going to do the same thing and it will be a wast of money
    Thanks in advance
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    Quote Originally Posted by Tommyjtr View Post
    Ok guy a I have a 2014 wrx stage 2 with exaust and turbo inlet and intake Mansfield hose access port Tuner from Cobb. I need some advise as now I'm scared that I'll be out. Grand for a stock ecu and it's going to do the same thing and it will be a wast of money
    There may be more money involved than that: even if you replace your ECU, you need to retain your old one so that Cobb can unmarry your accessport (I think that they ask you to send it in with the accessport), then you can install it on the new ECU. If you don't do this, you may need to revert the car to stock or pay to have the accessport unmarried for future use.
    David - '05 WRX
    Apr 2014
    Wichitafalls tx
    Yea I have already been in contact with Cobb and that's the plan this far . But I was just wondering if their has been anyone who has ever had their ap tuner do this
    Work In Progress GRBOXR's Avatar
    Jan 2014
    Long Island, NY
    Pretty sure Cobb is the only one capable
    Registered User Motoxdude6's Avatar
    Jan 2013
    Lubbock, TX
    dude i have a brand new stoc ecu that will work for your car ill aniihalate wahtever the dealer charges you for one, they are almost 800 bucks shoot me a text 806- 77 eight- 9 three 07 ill give you a killer deal
            MainFrame's Avatar
    Austin, TX
    ECU failure is NOT common. In fact, all of the failed ECUs I have seen over the years have been caused by the ECU being submerged in water. There is virtually nothing the AP can do to ruin the ECU.. it can brick the ECU if you shut the car off while you're in the middle of flashing maps, but that's fixable.
    Are you sure it's not your immobilizer giving you issues and the dealership is just trying to scam you?
    There are aftermarket ECUs.. for race cars. MoTeC is a pretty powerful aftermarket ECU, which costs anywhere from $4000 to $8000 depending on what sensors you want with it. And be advised you will have to rewire your car for it to work (which is easily another $1000 unless you do it yourself). Then there's the ViPEC i88, which is what I would like to have personally. That one only costs around $2300, and maybe another $1000 to install. Syvecs is another option, costs around $6000-$7000. That one seems to be pretty popular with GT-R owners.
    One issue with departing from stock ECU is that it will not pass emissions tests (unless you plug the stock ECU back in to get it tested). So you will still need a working OEM ECU to keep it street legal.
    Jul 2013
    Silicon Valley
    Care to explain this a bit?
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Zataks View Post
    Sure. All the AP does is allow you to read/write data to the ECU. It can't physically damage the ECU via software, so it can't really ruin the ECU.. you can [virtually] always change the data written on the ECU to something else, revert to stock if you want, whatever.
    Now if you're in the act of writing new data to the ECU and you sever the connection that data could end up corrupt because it wasn't able to finish. Which has the possibility of bricking the ECU where it won't interface the the AP because it doesn't even know what it is anymore. Still, that only has to do with the data saved on the memory chip, no hardware damage. Therefore you can always hook it up to the right rig (to gain access to the boot loader), erase the contents of the memory chip, and force working data back on to the chip. Then it's like a new ECU again.
            MainFrame's Avatar
    Austin, TX
    Think of it like a PC. There are a lot of things you can do to screw up the software where it will quit working, viruses, killing the power in the middle of operating system updates, etc. But no matter how bad you screw up Windows, it still has a working motherboard, CPU, powersupply, etc. All you have to do is delete the partition, format the hard drive, and reinstall Windows.. then it's like a new PC again.
    Apr 2004
    Southeastern PA
    Did you ask Cobb to recover your ECU? I had a bad time a while back: I think my accessport just fried my ECU
    Mods & Pics
    Apr 2014
    Wichitafalls tx
    Yes I have been untouched with Cobb they said they fully recovered the ecu and the ap tuner ! But when we putit in the car it still wouldn't start . And the dealer said if I touch the new ecu I have to pay for it if it fixes it or not !!! Who does that ?
    Oct 2011
    Santa Ana, CA
    Stealerships.
    Moderator Donkey's Avatar
    Da boonies,Va
    Most automotive stores will not let you return sensitive electronics. You could be having an issue with your immobilizer.
    2002 FORESTER S
    1998 FORESTER S
    Apr 2014
    Wichitafalls tx
    That's what I think it is but they said they checked that. But I'm about to just have it towed to Cobb and let them look at it
