2009 WRX AP trouble… Car Runs Terrible
Results 1 to 9 of 9
This is a discussion on 2009 WRX AP trouble… Car Runs Terrible within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I recently bought the Accessport from cobb this week. The first day I got the AP(thursday) I put on the ...
    Feb 2013
    North NJ
    I recently bought the Accessport from cobb this week. The first day I got the AP(thursday) I put on the stage 1 map(I have nothing but a SPT exhaust at this point). The car ran fantastic. This morning I put on the Cobb down pipe with the Highflow cat and realtime tuned it to the stage 2. I took it for a spin and it wouldn't build boost past 3 to 4k in 3 gear on. Then I thought I messed it up because i was suppose to reflash instead of the realtime. So I went ahead and reflashed the car to the stage 2 tune again. Same problem still occurred, so i uninstalled the accessport and left the downpipe on. It still doesn't build boost past 3 to 4k and the car stalls sometimes if I pop the car out of gear. NEED HELP…. not sure what is going on.
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    If the aftermarket downpipe is still on the car, keep the stage 2 map on the ecu.
    Then, can you do a few full throttle pulls in 3rd gear while logging IAM (DAM?), boost, FBKC, FLKC, RPM, MAF (g/s), wastegate duty cycle. If you share the logs with us, we may be able to tell you something. Although, you may have to drive around for a bit to get the IAM back up.
    David - '05 WRX
    Aug 2012
    Tucson, AZ
    Without looking at the car for myself it sounds like you may have an air leak somewhere. Check every single vacuum line, pcv valve, throttle body, turbo inlet..everytjing. best place to start
    Stinkeye member 520
    Feb 2013
    North NJ
    Let me restate… it builds boost to a point and then stops after 3,500 to 4,000… even shakes at times. This is now with the Stage 2 map back on. It will not allow me to pull all the way through 3rd gear without shaking or not allowing over 3,500 to 4,000. I will try to get the log on here so you guys can look at it.
    Feb 2013
    North NJ
    Can you tell me how to upload the datalog?
    Apr 2012
    not Ann Arbor
    do you use google drive? That is what I use to share. In google drive's online terminal, you can find an option to share if someone has the link; as long as you make the file public, then we can see it.
    David - '05 WRX
    Oct 2005
    Late Devonian
    First look for any cels. It sounds like limp home/safe mode but it should be flashing lights. You can check the IAM with the access port without driving - that would be helpful if you could get back to us on what that says so we can start.
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    There has to be an air leak some where. Check intercooler to throttle body hose and any other vacuum connections.
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
    Feb 2013
    North NJ
    Thanks for everyones help... It ended up being a leak, the tube blew off the throttle body.
