Best Stage 2 Maps for WRX '13
Results 1 to 15 of 16
This is a discussion on Best Stage 2 Maps for WRX '13 within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Just bought accessport v003 with intake. Should I keep the Cobb stage 2 stock map or you got a better ...
    Registered User SimPar's Avatar
    Apr 2014
    Levis, Quebec, Canada
    Just bought accessport v003 with intake. Should I keep the Cobb stage 2 stock map or you got a better suggestion. Don't have the exhaust though so I can't go too high. Thanks
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    I would go with whatever maps Cobb provides, so long as you have a Cobb intake. If you have a different intake then you will need to get the map for the specific intake from said intakes maker. Otherwise your only other option is to pay a professional tuner to build a map for you specific to your car (protune).
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    Apr 2014
    Got someone who can help me with that to program it. I've got a k&n typhoon intake, supposed to be more performant that the stock Cobb one. Can't wait to hear the sound of that!
  5. #4
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    I don't know anyone with a K&N on a WRX
    The ones I hear most about are the Cobb ( I have the Cobb) and A&E the Cobb tuner supports both.
    You need to be careful that you have the right tune for intake your using.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
  6. #5
    Registered User derekd2222's Avatar
    Feb 2012
    Virginia Beach
    Eric at Torqued Performance has maps for the K&N
    Torqued Performance
    2011 SWP Sedan
    Tuned by Kienan @ All Aspects Motorsports: 350WHP / 375 ft/lbs TQ on E85
    http://www.clubwrx.net/forums/builds...swp-sedan.html
  7. #6
    Jun 2013
    Danbury, CT
    You're running a Stage 2 map without a downpipe? Is that recommended?
  8. #7
    Registered User Rondizzle's Avatar
    Sep 2013
    Southern California
    Flash to a stage 1 map if you still have the stock downpipe
  9. #8
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    Stage 2 is meant to be used with an aftermarket down pipe. You can use stage 1 with stock, Cobb or AEM intake.
    With a KN intake you need either a pro tune, or an e tune from someone who has tuned a KN intake.
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
  10. #9
    Apr 2014
    K&n typhoon intake renders the same ways that the Cobb one and managed to tune in over the phone with local tuner. Even confirmed that you can run stage 2 without aftermarket exhaust, just have to be careful though. Thanks for yor help guys
  11. #10
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    You can't run a stage 2 map with the stock downpipe. Stage 2 is by definition an aftermarket down pipe with the appropriate tune.
  12. #11
    2009 WRX Sedan Blammo's Avatar
    Dec 2012
    British Columbia, Canada
    Quote Originally Posted by SimPar View Post
    uhhhhhhhhh.....NOPE.
    wrong.
    you can do some damage to engine internals running a stage 2 map with stock exhaust!
  13. #12
    Apr 2014
    Thank you for all your help. I've been running stage 1 since a year not and add it mapped with my k&n typhoon intake. I want to go stage 2 this spring and currently shopping for a downpipe but not catless. I heard good things about the invidia 3" but was wondering if any of you know of the one below:
    http://pages.ebay.com/link/?nav=item...d=400806523217
    Will it work directly or do I need other parts to install it. I want to make no modification to the original car parts so I can switch back to original downpipe if needed. Of course I'll take it for reprogramming afterwards. Thank you again
    Sent from my iPhone 6 using Tapatalk
  14. #13
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    I shy away from parts on ebay, man. If you want a good, cheap downpipe, the Invidia is a great option.
    I have an STi with an intake and no tune, I never change my oil, and my wheel spacerz are mad tyte.
  15. #14
    Apr 2014
    Ive been purchasing a lot from eBay for all the cars I've own and never add any problem. As long as you stay clear of chinese parts
  16. #15
            MainFrame's Avatar
    Austin, TX
    And Rev9 is one of those cheap knock off Chinese brands.. you CAN get good name brand parts on eBay, but in most cases you can get the exact same part for less money from a local vendor instead.
    If you want to steer clear of the knock off Chinese stuff, then you need to know exactly what brand you're looking for before searching on eBay.
