Check engine ligh 03 wrx
Results 1 to 7 of 7
This is a discussion on Check engine ligh 03 wrx within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; My check engine light came on and I have a full tb exhaust and cool accessport map stage 2 running ...
    Oct 2013
    wichita ks
    My check engine light came on and I have a full tb exhaust and cool accessport map stage 2 running so the light has been off since I downloaded the map but now my check engine light is on after about 4 months of having the engine management. Should I re flash the map? The accessport is saying my heater control circuit is low.also on my tripple pod gauges the oil press guage is below the zero and in the red but no oil light is on. Please help
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Exactly what code is it throwing and what does it say. We'll need this to properly diagnose the problem here. I believe the code is P0031. But make sure thats what it is, also is it bank 1, sensor 1; sensor 2, etc. ???
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    Sep 2013
    Western Maryland
    Most of the time this means you have a faulty o2 sensor, or the wiring to the o2 sensor is damaged or has a short in it.
    Stink-Eye Mob #301
    Oct 2013
    wichita ks
    Yes, p0031 and bank 1 sensor 1. If it was the o2 sensor I didn't think the check engine light would even come on? That's one of the reasons for the cobb ap I thought?
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    This link has a lot of info about troubleshooting that code. I've used it myself to much success.
    http://www.scoobymods.com/showthread...82f6a39e5&amp;
    There's a problem solving table that helped me a lot. I ended up replacing the sensor at a little over 90 kMiles, which is a normal lifespan for it.
    David - '05 WRX
    Sep 2013
    Western Maryland
    Quote Originally Posted by vaugghann View Post
    The AccessPort does not enable codes from popping up. If something goes wrong, for example your o2 sensor, you will still get a CEL. The accessport will only allow you to read the code and clear it. The only way to actually disable a CEL code from popping up is if a tuner actually programs your car to do so. The link that Obeisance posted will further explain things on how to fix it.
    Stink-Eye Mob #301
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by WRX-maniac View Post
    Actually, not quite. Cobb stage 2, for example, defeats a number of codes regarding catalyst efficiency.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
