07 sti Not reaching target boost
Results 1 to 7 of 7
This is a discussion on 07 sti Not reaching target boost within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So I come to you once again with a problem. I'll just get right to it: I have noticed the ...
    Aug 2013
    So I come to you once again with a problem. I'll just get right to it: I have noticed the past couple of weeks that my car isn't hitting the boost that it used to. I have always been able to easily kick it to 15 psi and max at 19-20. Now, I can crank it to 10 psi and after that I have to really bust it out in 3rd or 4th to get it to 16. I saw on my AP that I hit 17.2 or so, but I was taking it full throttle to 7000rpm every shift to 5th gear. In the past I have been able to easily get 19-20 even over boosting at 21. Also, when I say I used to easily get it to 15 psi, I mean that now with the same throttle down I'm only getting that 10 psi instead.
    The only thing I have done different that I can think of, since it started, was put 93 OCT in her. I think thats when it started, because that was about two weeks ago.
    Specs:
    TurboXS TBE
    Injen CAI
    Stage 2 93oct OTS
    88k miles
    Any thoughts on what it could be and what I should do?
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Check under the hood for boost leaks. Look at the intercooler connections. If you can't find anything obvious then get a leak test done. It is not the gas.
    If you're running the Cobb map, what is boost target?
    Resident Tuner @ WTF Tuning
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by Creativename01 View Post
    What fuel were you using before? I would do a boost leak test,clean the MAF and datalog the car. Is the CObb map you are using specifically for the Injen intake?
    2002 FORESTER S
    1998 FORESTER S
    Aug 2013
    Target boost is 19.3. Like I said, I was over boosting before at 20 and 21. Can't even get past 17.5, and thats trying really hard.
    I was using 91. Cleaned the MAF and it changed nothing. The map is not specifically for the intake, but I have had no problems with it for months until now
    Da boonies,Va
    Datalog the car
    2002 FORESTER S
    1998 FORESTER S
    Palmyra, NJ
    Injen intake is notorious for being a major piece of ****.
    Also have you tried the HWG Stage 2 map?
