WRX goes very lean in OL. help
Results 1 to 15 of 16
This is a discussion on WRX goes very lean in OL. help within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hello I need some help in order to understand where is the problem. The car has lean spots during mild ...
    Hello
    The car has lean spots during mild acceleration.
    AFR is jumping to over 15
    Time in the log 19.10 to 19.30 and 22.56 to 23.04 is a good example. Normal driving
    Please see the log file
    The car is EU 2001 WRX with modded injectors, silicone intake, VF43 and S202 like tune on H98 europe fuel.
    https://mega.co.nz/#!g9dWmCYC!DKQfuS...pYUj5gtcKhkIbI
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Can't access the log file, but what WBO2 are you using to read the AFRs?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    The WB is the subaru one on the UP pipe. I can not upload the log, but it is available from Mega (the link in first post)
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by pavlik1 View Post
    You can't use that to monitor OL AFRs.
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    Subarus don't come with a wide band from the factory.. only narrow band. To dial in AFR you need to install an aftermarket WBO2 in the downpipe, 24"-36" from the turbo, and upstream from any catalytic converters.
    I don't want to enter in discussion regarding this, Under hard acceleration i is showing close to the target I have in the fueling map. There is something wrong since during hard acceleration the car like take off when the AFR drops down to 11.5 for example.
    Under light acceleration the "switching" doe not happen and the AFR is 15-16 at 0 to 4psi boost where the log shows OL . please see the log at app.19.10 where start acceleration and going over the gears
    can you open the file?
    zax
    zax is offline
    Nov 2008
    No, I can't open the file. And yes you SHOULD enter the discussion about this. You're attempting to use improper equipment to make a diagnostic call.
    I am far more concerned with the fact that the AFR is showing close to the target during hard acceleration. Because the pressure in the header is much higher than ambient, the stock O2 sensor should read very rich. This is how a zirconia WBO2 sensor works. I'm questioning how the car was tuned and if you are running lean all the time.
    FWIW, your O2 sensor is in the header, not the Uppipe
    Facebook me here
    zax, I am aware that the A/F sensor before the turbo when under pressure read rich, and I am sure my car is a bit lean.
    The problem I have is understanding what happens when the manifold pressure is around 0, then the AFR is hiting 15-16 - very bad. I asume the sensor is reading OK since no pressure.
    Below is a part of the log
    Stop calling the stock front O2 sensor a narrowband... - NASIOC sure it is not the widest but is someting
    for me first file in Mega is working. I use Epifan ecuedit viewer to open it
    zax
    zax is offline
    Nov 2008
    Please post your Short Term and Long Term fuel trims.
    Facebook me here
Name:	LearningView_SS_04-Mar-14 7 54 29 PM.jpg
Name:	LearningView_SS_29-Apr-14 2 45 55 PM.jpg
            MainFrame's Avatar
    Austin, TX
    Has it always been like that? Looks like the MAF needs to be rescaled (or you have a leak). You are maxing out corrections in the low range.
    and 5.63 is a lot of timing to pull, the car is not happy there, that's for sure
    is it so if the car has leack, i.e, sucking air, the 0-5.60 will be positive? this may be due to injector latency, a bit too much
    around this 5.63 timing I already removed 3 degree from the timing
    zax
    zax is offline
    Nov 2008
    Here is my guess: you need to retune the injector latency (may not have been tuned correctly). If the TIE was not tuned correctly or the IPW compensations have not been updated for the larger injectors, that explains the brief lean condition at low throttle.
    Facebook me here
    Zax, sorry but I am not as good with the abreviations, what is TIE and IPW?
    here is my last:
    injector latency table
    [Table2D]
    6.5 9.0 11.5 14.0 16.5
    2.99 1.69 1.18 0.88 0.58
    and flow scaling
    [Table2D]
    Injector Flow Constant
    820.08
    before was 800 but the same problem
    and the Tip in
    [Table2D]
    0.4 2.8 5.2 7.5 9.9 12.3 14.6 17.0 19.4 21.7 24.1 26.5 28.8 31.2 33.6 35.9 38.3 40.7
    0.26 0.32 0.38 0.48 0.58 0.70 0.83 0.96 1.09 1.22 1.34 1.47 1.60 1.76 1.92 2.08 2.24 2.40
    the car is not easy to start compared to stock injectors, so far didnt find any good settings fro latency
    zax
    zax is offline
    Nov 2008
    TIE = tip in enrichment
    IPW = injector pulse width
    Facebook me here
