AP boost gauge accuracy
Results 1 to 5 of 5
This is a discussion on AP boost gauge accuracy within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hey all, about a month ago I went stage 2 (mods in signature) and used the stage 2 93 octane ...
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Hey all, about a month ago I went stage 2 (mods in signature) and used the stage 2 93 octane map from perrin for their cai. All in all the car feels great, but im worried that i may be overboosting a bit. I had a prosport mechanical boost gauge, which i removed a couple months ago bc i could not get it to zero out and feel it was very inaccurate. So I have been using the boost gauge on the AP to monitor boost. Now im not sure what the target boost is for my car at stage 2, but i thought it was suppose to be 18.5psi. My car, according to the AP, has hit a peak of as high as 19.87 psi on a 3rd gear pull. Should I be worried at all? Or does this seem to be ok? Im just not sure if the boost readings on the AP are accurate or not. Thanks in advance!
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    Sep 2013
    Western Maryland
    Nobody?
    Stink-Eye Mob #301
    Registered User derekd2222's Avatar
    Feb 2012
    Virginia Beach
    Mine reads very accurate, target boost is 20psi in 3rd gear and I regularly hit between 19.8 and 20.1. I'm not familiar with Perrin's maps, but a stage 2 map with Torqued Performance is 19psi. You might want to check with Perrin and see what your target boost is.
    2011 SWP Sedan
    Tuned by Kienan @ All Aspects Motorsports: 350WHP / 375 ft/lbs TQ on E85
    http://www.clubwrx.net/forums/builds...swp-sedan.html
  5. #4
    Sep 2013
    Western Maryland
    Awesome, good to know. Thanks for the response. So my hitting in the high 19psi is normal for a 3rd gear pull. I talked to perrin and they said that everything sounds fine. I havent sent them any datalogs yet. But i know they said that all they do is take the cobb stage 2 93 octane map and change the maf parameters to their cai.
    Stink-Eye Mob #301
  6. #5
    Registered User SettleDown's Avatar
    Feb 2014
    Fort Wayne, IN
    Also, they is normally a +/- of the target boost that is still considered safe. As stated, look into documentation of the tune, but normally 1.5+/- is considered safe.
