2011 WRX tuning help!!
Results 1 to 5 of 5
This is a discussion on 2011 WRX tuning help!! within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I just finished installing a Perrin up-pipe and a full 3" Perrin (bell mouth back). I also have the Cobb ...
    Apr 2014
    I just finished installing a Perrin up-pipe and a full 3" Perrin (bell mouth back). I also have the Cobb V3 access port coming in the mail. This is a daily driver and I like to get on it a little bit every once in a while. Which map should I set my ECU to and is 93 octane still safe? I didn't notice any lights come on in the dash after I started it up post-installation. I just let it run for 10 minutes and searched for leaks. Will engine lights light up once I get some mileage on the new upgrades? I read some other forum posts and they talked about blowing motors without flashing or mapping the ECU to safely install engine mods. AM I AT RISK OF BLOWING MY MOTOR IF I DRIVE BEFORE I UPDATE MY ECU???!!!
    ANY GOOD ADVICE IS MUCH APPRECIATED.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Do NOT start your car before you flash the map. Also, read the map notes! It really is that simple.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User Mitch08WRX's Avatar
    Jul 2013
    GR, MI
    DO NOT run the car until it is flashed with the AP. Otherwise, yes, you do risk blowing it up.
    Registered User 386WRX's Avatar
    Jan 2014
    Port Orange Florida
    Yes, you should have researched a little bit before you dropped a grand on exhaust.
    Do not run the car, or drive it.
    When you get the AP, flash to stage 2 93 oct map. And use 93 oct gas ONLY.
    Your downpipe is catted, right?
    Sent from my LG-E980 using Tapatalk
    Apr 2014
    Lightbulb
    Yes my DP is catted. I haven't run the car more than 5 minutes and won't till it's tuned. Thanks all for the very helpful insight.
