Need a logging file
Results 1 to 15 of 15
This is a discussion on Need a logging file within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Anyone able to send me the logcfg.txt that they use with open port? I have no clue what file from ...
    Mar 2014
    Eglin Air Force Base, Florida, United States
    Need a logging file
    Anyone able to send me the logcfg.txt that they use with open port? I have no clue what file from open ecu to use, and I figure people here would have some good customized ones to use.
    Sent from my SPH-L710 using Tapatalk
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    There are a few of these around:
    OpenPort LogCfg Generator
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Mar 2014
    What would I use as my RomRaider profile? And how do I know what type of ECU my car has?
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by KingAroan View Post
    1. Create your logging profile in RomRaider -- Select all your logging parameters and click "Save profile"
    2. The ECU ID is accessible when you load your map in RomRaider. As a cross-check, you can also reference the IDs here: RomRaider • View topic - Stock ROM List
    Facebook me here
    Mar 2014
    Last question then, what are the best parameters to monitor to start off with?
    Mar 2014
    Here is the log file I created, if you can think of any other parameters I should add or see ones that I should delete let me know.
    zax
    zax is offline
    Nov 2008
    Depends on what you are logging. What stage of the tuning process are you currently undertaking?
    Facebook me here
    Mar 2014
    Just started. Trying to tune it up for a little bit of performance, all I have done to the car is an up pipe. I want to put my SRI on but that requires a tune. Once I know how to read the logs and adjust accordingly I'll put that on
    zax
    zax is offline
    Nov 2008
    Exactly how much experience do you have? No offense but you can't just wake up one day and tune your car.
    Do you have a WBO2? If so, which brand?
    Facebook me here
    Mar 2014
    No tuning experience alot of programming though
    Mar 2014
    No wbo2 yet either
    zax
    zax is offline
    Nov 2008
    No wbo2 yet either
    Then you can't tune for your intake. The best you can do is tune the lower mass airflow cells using CL feedback: HOWTO: One Man's Way of Scaling a MAF - NASIOC
    However, OL scaling is simply not possible without the WBO2.
    Facebook me here
    Mar 2014
    Thanks for the link. What is a good brand for a WBO2 sensor
    zax
    zax is offline
    Nov 2008
    The two most common are the Innovate LC-2 and the AEM UEGO. I opted for the latter.
    Facebook me here
    zax
    zax is offline
    Nov 2008
    Let me correct this: It is possible with an EGA, but those are generally $$
    Facebook me here
