36lbs on cobb stage1+ HELP !
Results 1 to 15 of 17
This is a discussion on 36lbs on cobb stage1+ HELP ! within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hey guys, my buddy has a 2014 WRX hatch. He's running the Cobb stage1+ 93 SF map. He is somehow ...
    Feb 2014
    Rochester NY
    Hey guys, my buddy has a 2014 WRX hatch. He's running the Cobb stage1+ 93 SF map. He is somehow reading 36lbs of boost every now and then, which we are both puzzled. I feel like the AP is reading wrong or he would have blown something up. (Stock turbo) He hasn't Datalogged during this, but took a picture after he saw what his AP read. Anyone else have this problem or see anything like this?
    Thanks Chris.
    Registered User WREXXY's Avatar
    Oct 2012
    CT
    its reading -9.35...? so he was off boost, pulling a "vacuum"
    Feb 2014
    Rochester NY
    -9.35 is realtime. Bottom right of the "Boost" Gauge was peak boost.
    Oct 2012
    CT
    did he actually see the real time hit 36?
    Feb 2014
    Rochester NY
    Yes but he obviously couldn't take a picture/expect for that too happen. It's only happened 2/3 times since he went stage1 (about a week).
    Oct 2012
    CT
    did the car act differently when it happened?
    Oct 2012
    CT
    fuel cut, loss of power, spike in power followed by bucking/loss of power?
    Feb 2014
    Rochester NY
    None of that which is why I'm pretty sure it's a mis read somewhere. I know fuel would get cut before a certain amount of boost. And no CEL.
    Oct 2012
    CT
    i googled it, seems like it's happened to some other ppl. a guy with a focus st saw 65. i'd contact cobb. and maybe make sure he has a good connection to the obd2 port.
    Feb 2014
    Rochester NY
    Okay thanks for the help WREXXY
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    36 PSI is probably the manifold absolute pressure, not relative pressure. Manifold absolute pressure is the total pressure in the manifold (14.7 PSI or 1 atmosphere + boost pressure). Even then, however, this means that you are having boost spikes upwards of 22 PSI.
    I'd give Cobb a call.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jul 2012
    Rocky Top
    P_abs = P_gauge + P_atm ...just in case anyone forgot that formula. I'm here for you. Otto Cycle FTW....
    Feb 2014
    Rochester NY
    Thanks for the input guys.
    Registered User Rmurphy_22's Avatar
    Nov 2013
    Signal Hill, CA
    Thank Cobb for the extra boost, 36psi...wow
            MainFrame's Avatar
    Austin, TX
    Either it's reading absolute pressure, or it's wrong. The stock MAP sensor pegs out at 23.5psi, so even if you really did hit 36psi, it would only read 23.5psi.
