Just got Cobb AP. Do I have a knock issue?
Results 1 to 15 of 21
This is a discussion on Just got Cobb AP. Do I have a knock issue? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So the car is a 2013 WRX. I just put the 93 oct stage 1 map on the car, everything ...
    Mar 2014
    So the car is a 2013 WRX. I just put the 93 oct stage 1 map on the car, everything else is stock.
    I did a 4th gear pull and I think there seems to be a lot of feedback knock. This is my first time doing a datalog and I forgot to change any parameters, so all of these are just the default ones. Anyways here's the spreadsheet.
    https://docs.google.com/spreadsheet/...Gc&usp=sharing
    Jun 2013
    Chicago, IL
    You're supposed to Datalog during THIRD Gear pulls.
    Sent from my LG-D800 using Tapatalk
    Mar 2014
    so that makes this data useless? What's wrong with datalogging a 4th gear pull?
    Feb 2014
    Kansas
    Hm....im kinda new to this aswell but im reading up and getting some info, i did a couple pulls myself on a stage 2 93 octane map on a 07 wrx. My clutch was slipping so i was backing off a bit, but i did a 2k to 6k 3rd gear pull
    You could compare your data to see if your getting about the same stats.
    https://docs.google.com/spreadsheet/...1TTVYTFE#gid=0
    The feedback knock is very strange though and should not be happening, hopefully someone with more knowledge could help you out with that. Sorry I couldnt help to much
    Feb 2014
    Kansas
    Quote Originally Posted by tom1126 View Post
    I believe its because 3rd gear can get the best data for the logs since that when you get the most power out of you car, but im just speculating
    I'll look at the log tomorrow, but there is nothing wrong with a 4th gear log, other than the speed it puts you at if you carry it to redline.
    Resident Tuner @ WTF Tuning
    Jun 2013
    Chicago, IL
    Quote Originally Posted by Dgatman View Post
    Believe you're correct. Even instructs you to pull from 2500>Redline in third gear for the most accurate log. Nevertheless, random knock during normal driving is common, but you shouldn't see knock under WOT.
    Mar 2014
    You have that set to private. You're gonna wanna go into that doc, go to the top right and click share, then click share with anyone who has this link.
    Awesome, that's what I thought. I did a third gear pull today, but can't upload it til I get home from work.
    Jan 2012
    Philly Area
    Try to get that third gear pull up. Your fourth gear pull isn't the full rpm range (probably cause you realized the speed running through 4th gets you to)
    You aren't getting real high knock values, usually if it's 1.4 or less than it's incidental or false. What's the road you did your pull on like?
    I'd just keep logging periodically and see if any learned knock shows up.
    - Will
    Mar 2014
    Yea, was going a bit too fast, had to cut it. The road was flat interstate, getting on from the on ramp, slightly uphill, but not much.
    When you say learned knock, are you talking about fine knock learning? If any of that shows up, how bad is that?
    Jan 2012
    Philly Area
    Basically, the feedback knock is from when the knock sensor itself picks something up. Many things can cause that from actual knock to going over a bump in the road to a rattling heatshield (I think I've heard of that happening). The fine knock learning is something that the ECU does when you continually experience feedback knock under the same circumstances (rpms, load, etc). So if you are seeing correction in that column, it indicates that you more likely are getting real knock because it has been repeated many times.
    - Will
    Mar 2014
    Ah, okay, thanks. So I should keep an eye on the fine knock to confirm I'm getting real feedback knock.
    Jan 2012
    Philly Area
    Yeah. I think you should definitely get a few full rpm range pulls in 3rd done and post them up. Then periodically log and keep an eye out for fine learning.
    - Will
            MainFrame's Avatar
    Austin, TX
    Actually, the car should make more power in 4th.. more load. 4th gear data log is as good, if not better than 3rd gear.. but like EJ said, topping out 4th gear at 7100rpm has you moving pretty fast for public roads.
    Feb 2014
    Kansas
    Heres the datalog i open for you to read
    If anyone can tell me whats going on that would be great
