Stage 2+ running rich and over boosting
Results 1 to 6 of 6
This is a discussion on Stage 2+ running rich and over boosting within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hey, I have a 2014 wrx stage 2+cobb sf intake. I'm running a invidia catted downpipe with the q300 exhaust ...
    Jan 2014
    Newton NJ
    Hey,
    I have a 2014 wrx stage 2+cobb sf intake. I'm running a invidia catted downpipe with the q300 exhaust and the cobb stage 2 ots map with normal wastegate. My AEM wideband is reading 10-10.5 on WOT pulls and 14.2 at idle. Also I'm peaking at 20 psi when target is 18.5. Could it be a boost leak? Anyone's help would be greatly appreciated. Thank you I advance.
    -Tom
    Registered User wrxnguyen's Avatar
    Jul 2013
    714 Orange County
    Try running a lower waste gate map.
    Jan 2014
    Newton NJ
    I'm gonna do that, I also read that running a 91 octane map would be better than the 93 one I'm on right now. Is that true?
            MainFrame's Avatar
    Austin, TX
    If you're filling up with 93 then you should be able to run the 93 map.. but the 91 map will have a greater safety margin.
    In my experience the Comm OTS maps are all pretty rich.. I would say 10.5 is okay, but 10:1 at WOT is a little excessive. Not quite rich enough to hurt anything, but power and fuel economy will suffer.
    Jan 2014
    Newton NJ
    Mainframe, I'm only assuming that it is 10:1 the AEM wideband gauge doesn't go lower than 10:1 so one can only assume. Which worries me, any ways I can check for leaks? I know water and soap will work, but any other ways I can go about this? Thanks
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by 14swpwrx View Post
    ..any other ways I can go about this? Thanks
    Use a boost leak tester (basically a cap for the intake with a valve stem on it), pressurize the system with an air compressor, and listen.. if you have any leaks you should hear them hissing.
