Cobb AP datalogs 2014 WRX
Results 1 to 2 of 2
This is a discussion on Cobb AP datalogs 2014 WRX within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Did some data logs last night after installing the AP and a stage 1 OTS tune. Car is all stock. ...
    Registered User ZXNasty's Avatar
    Nov 2013
    Murray, KY
    Did some data logs last night after installing the AP and a stage 1 OTS tune. Car is all stock. All three pulls are in 3rd gear from ~2000rpm to near redline.
    AP was reading peak boost right at 16.5 +/- .5psi. No knock detection that I could see. Have a look and let me know if I'm all good.
    https://drive.google.com/file/d/0B5U...it?usp=sharing
    Registered User Scoob1318's Avatar
    Apr 2013
    You should also measure a/f ratio when you log. It's a critical indicator, however everything thing else seems to be fine
