Cobb v3 stage one map question - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Cobb v3 stage one map question within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; No offense on my part, you just re-enforced what I said. No problem, all good!...
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Dec 2013
    I run 93 in my car but loaded the 91 map due to better knock protection.
    Sent from my SM-N900V using Tapatalk
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Not sure what the confusion is here. The 93 map is designed to be used with a minimum of 93. The 91 map is designed to be used when the minimum available is 91. Of course the 91 map will be fine with 93, but if you have 93 available, then you have the option of running the slightly more aggressive 93 map.
  5. #19
    Dec 2013
    He is correct, but like in my case I was seeing slight fbkl on the 93 map. It wasn't enough to be worried about but I would rather have a safe engine than a more aggressive engine with risk. Running the 91 map with 93 fuel is just a precaution against knock.
  6. #20
    Registered User Crazyced's Avatar
    Dec 2013
    Ottawa
    Quote Originally Posted by Mr.NiceGuy View Post
    I've been using 93 with the 93 map. Every time I get a knock report. It's not knocking all the time and only a few times over the allowed 1.4 false knock. They are random and usually in low rpms. Should I be concerned?
    What matters is sustained knock you get at WOT or at least when in boost. Random small knock spikes that you get while cruising are just noise and nothing to worry about.
    2004 Subaru Impreza WRX
    2004 Dodge Neon SRT-4
  7. #21
    Sep 2015
    I'm considering the same sort of situation as the original poster. I have loaded the 93 Octane Map and have access to 93 Octane most of the time. Running Stage 2 2005 WRX Wagon 2.0.
    Can I pull a data log with the old original AccessPort V1 to watch for knocks? Will a check engine light ever display if there is knocking?
  8. #22
    Sep 2015
    Just a question guys , my 2013 wrx has a down pipe , invidia cat back , Cobb air box , can I run a stage 1 map or should I stick with a stage 2+ map off the AP
  9. #23
    Sep 2015
    This is my mod list should I be on stage 2+ on AP
    Attached Thumbnails Attached Thumbnails image_1442766343498.jpeg   image_1442766358435.jpeg
